Best tire sizes
KJoeZ61
Northampton Pennsylvania
I just bought a 71 Scamp and the tires are questionable. As it sits now it has small bolt pattern 14" x 6" wheels with 185-70R-14 upfront and 14" x 7" wheels with 215-60R-14 in the rear. The only clearance issue I see is the rear tires are about 1" from the leaf springs. Can I go any bigger?
Joe
Joe, you can definitely go bigger...the limitation will be on those wheels first. 185 is probably about right for a 6" wide wheel, you could go a bit wider on a 7" wide wheel...
Before you do anything, it sounds like you know how much space is there with your current setup. Armed with this data, this tool should tell you everything you want to know.
Wheel-Tire size comparer - RIMSnTIRES.com
