Best year(s) 904 for a street/strip car?
Discussion in 'Mopar Racers Forum' started by motorpirate, Jul 11, 2018.
  1. motorpirate
    motorpirate serial mopar owner
    165
    34
    Nov 4, 2007
    northern KY
    Local Time:
    12:58 PM
    Another thing on the back burner, After I get the rear diff sorted out (eBay used 3.55's are whiney junk!! replacing this week with a virgin set) we are going to start the Magnum swap.
    At first this will be on the '66 904 original to the car (18 spline converter) which works fine, but if i am going to go into it to better suit the Magnum set up I think it makes sense to build a 27 spline trans to have a better choice of convertors, etc.
    Plus that will leave me with a fine running 273 2bbl/904 combo to put in Dads '48 dodge?
    So, what year/years would be the best to look for? Car is a'66 Barracuda weighs 3400.
    3.55 rear and will be driven to the track about 40 min away on the interstate at 65/70 mph.
    Will NOT be a manual valve body.
    If i know what to look for, while Dany and I are busy with the motor, I can keep my ear to the ground, I know I can kick up a good core to go through, if I know what year range to look for.
    Again, thanks for all your help guys!!
  2. xLURKxDOGx
    xLURKxDOGx "An angel fat, at satan's feast"
    2,091
    322
    Dec 27, 2013
    PHX
    Local Time:
    10:58 AM
    My experience has been with the latter years 70+ but only to simplify the torque converter debacle.
    Jake
  3. 70aarcuda
    70aarcuda Master Hoader of SBM FABO Gold Member
    13,403
    1440
    Jan 16, 2005
    las vegas
    View My Photos
    Local Time:
    10:58 AM
    I believe it is the 72 oe 73 and newer is what you want...one of the servos changed..
    • Like Like x 1
    • Agree Agree x 1
    • motorpirate
      165
      34
      Nov 4, 2007
      northern KY
      Local Time:
      12:58 PM
      And how to tell what year a trans is, if it's not in the car???
    • 72Dart6pack
      72Dart6pack Harder Better Faster Stronger.
      2,107
      1290
      Feb 1, 2016
      Roseville Michigan
      Local Time:
      1:58 PM
      Casting dates on the parts are a good start.
      • Like Like x 1
      • cosgig
        cosgig MoBro Inc. FABO Gold Member
        10,451
        2709
        Jul 20, 2008
        Pinckney, Michigan
        View My Photos
        Local Time:
        12:58 PM
        The 66-67 904 does have a front and rear pump, if that makes any difference. And the converter debacle is easily overcome with an annular ring.
        • Like Like x 2
        • 70aarcuda
          13,403
          1440
          Jan 16, 2005
          las vegas
          View My Photos
          Local Time:
          10:58 AM
          on the driver side just on the pan rail...there is a number stamped that starts with a PKxxxxxxxx then xxxxx
          • Like Like x 1
          • crackedback
            crackedback FABO Gold Member FABO Gold Member
            17,761
            1695
            Aug 7, 2005
            92201
            Local Time:
            10:58 AM
            71+ are the better ones IIRC. There is a difference on the outer case where the Servo is located as Tony mentioned.
            • Like Like x 1
            • Agree Agree x 1
            • motorpirate
              165
              34
              Nov 4, 2007
              northern KY
              Local Time:
              12:58 PM
              is a front and rear pump any advantage?
            • Mike 340
              Mike 340 Well-Known Member
              119
              30
              Jun 21, 2016
              Canada
              Local Time:
              1:58 PM
              I think that you could push start with a rear pump. ?
              • Agree Agree x 1
              • Charrlie_S
                Charrlie_S Well-Known Member
                2,269
                284
                Oct 17, 2005
                Silver Springs, FL
                Local Time:
                1:58 PM
                1965 was the last year with a rear pump.
              • furrystump
                furrystump Well-Known Member
                351
                183
                Nov 13, 2004
                Local Time:
                6:58 PM
                I know there were 904’s that came with a 5 clutch drum. I don’t know the specific year, but I think you can build any 904 to survive behind a pretty serious motor. I know of a 5 clutch 904 in small block demon that runs 11.70’s and it’s not even working hard
                • Thanks! Thanks! x 1
                • mderoy340
                  mderoy340 Well-Known Member
                  1,731
                  417
                  Aug 2, 2012
                  Melbourne FL
                  Local Time:
                  1:58 PM
                  Vin# pad will also tell year.
                  I run a 84 lockup 5 clutch low gear set from a Diplomat. TF2 shift kit, lockup circuit plugged, Turbo Action 10" S800 26 spline 3200 tight converter, 3.91 gear. 340 375-400 real world hp, Launch car at 2k 1.65 60', 11.77 best so far in ok air. I pulled the tranny after 400 passes and it looked good so it when back in with new seals only. Lockup input shaft is plenty strong for what I'm doing street/strip drive 100 miles round trip to the track.
                  • motorpirate
                    165
                    34
                    Nov 4, 2007
                    northern KY
                    Local Time:
                    12:58 PM
                    So sounds like I'm looking for a Volare/Diplomat/5th Ave trans..
                  • 70aarcuda
                    13,403
                    1440
                    Jan 16, 2005
                    las vegas
                    View My Photos
                    Local Time:
                    10:58 AM
                    the 4 disc drums can be outfitted with 5 disc....just have to use the thin .068 clutch disc instead of the 086 thickness....I got 4 904 like that......
                    • Like Like x 1
                    • rumblefish360
                      rumblefish360 so close yet so far away
                      31,399
                      3787
                      Jun 21, 2005
                      New York, on a Island
                      View My Photos
                      Local Time:
                      1:58 PM
                      Do tell about this annular ring!
                    • Charrlie_S
                      2,269
                      284
                      Oct 17, 2005
                      Silver Springs, FL
                      Local Time:
                      1:58 PM
                      67 down 904 had a small input shaft, and pilot on the engine end of the converter. This matched the size of the pocket in the end of the crank, for small blocks, and slant sixes. In 1968 the crank pocket, converter pilot, and input shaft got larger. This is why you cannot put a 67 or earlier engine, up to a later trans. You can put a later engine up to the early trans buy using an adapter ring in the end of the crank.
                      • Thanks! Thanks! x 2
                      • 408 swinger
                        408 swinger Well-Known Member
                        232
                        96
                        Nov 12, 2010
                        Iowa
                        Local Time:
                        12:58 PM
                        Isn't the output a little latger on the 73 up, also?
                      • Charrlie_S
                        2,269
                        284
                        Oct 17, 2005
                        Silver Springs, FL
                        Local Time:
                        1:58 PM
                        If you mean the output shaft where the front drive shaft yoke slides in.
                        No. 1966 up all the same. 1965 down, has the flange.
                      • 408 swinger
                        232
                        96
                        Nov 12, 2010
                        Iowa
                        Local Time:
                        12:58 PM
                        go
                        Gotcha!
                      • rumblefish360
                        31,399
                        3787
                        Jun 21, 2005
                        View My Photos
                        Local Time:
                        1:58 PM
                        Thanks Charlie. For some reason, I thought it was an adapter ring on the trans to use a later converter.
                      • Charrlie_S
                        2,269
                        284
                        Oct 17, 2005
                        Silver Springs, FL
                        Local Time:
                        1:58 PM
                        Just a FYI
                        I used to get my converters built (hard to get them now) with the small pilot, and the large splines. That way I could use the early engine with the late trans. Or use the early trans, by changing the front pump and input shaft, to the late items (they will interchange). Or use the late engine, by using the adapter ring. Gives me more options.
                        PS: I like to use the pushbutton trans with the late front section parts, with either late or early engines.
