hemi446
For Sale big block 727 out of my 67 Barracuda it was behind my 446 Hemi motor. It works perfectly.
The fluid has been changed every year regardless of mileage. The transmission has 10,921 miles on it now.
I’m only selling it because I’m putting a TREMEC transmission in the car now.
The transmission was built by A&A Transmissions in Camby IN.
It has all the good A&A parts in it bolt in sprag, aluminum drum, lightened sun gear shell, reverse pattern manual valve body with the low band applied. This keeps the sprag from failing
Also included is the Turbo Action 10” converter it is about a 3000-3200 stall, the dip stick and tube, front transmission shield, and the transmission cooler which is a big one that came on the full size vans and the lines.
I may the lines to fit my car but they would work with any big block car they ran along the side of the block and up around were the battery tray would go and through the front core support. Asking 1800.00 plus the ride if you wanted it shipped I would make a crate for you for 75.00 and you would have to send your trucking company to pick it up. Please ask any questions and I will try and answer them as best as possible.
