[FOR SALE] Big Block Cylinder Head Shafts For Mechanical Rocker Arms - New
Rocket
CT
I have some sets of big block Mopar rocker arm shafts for big block cylinder heads that use a stock dimension rocker arm shaft. These shafts are made here in the U.S. from USA produced cold drawn carbon steel tubing of ~ 0.190” wall thickness and hardened. They feature banana groves and oiling holes that are positioned for the loading of mechanical rocker arms. These shafts have removable and reusable end plugs for inspection and easy cleaning. These are drilled on center for 3/8” hold down bolts and are for use on big block Mopar cylinder heads including stock Mopar heads, aftermarket cylinder heads including Edelbrock, Speedmaster or other similar cylinder heads requiring a stock dimension rocker arm shaft for use with mechanical rocker arms. They are far thicker and stiffer than stock or many aftermarket shafts to minimize flex with stiffer aftermarket valve springs and provide superior oil control with the grooves that spread the oil over the load area of the shaft and rocker arms.
Price is $190 for the pair shipped within the lower 48 states.
I can ship elsewhere for the additional shipping cost.
PM me with any questions.
