bigblock A body radiator
Cold Case Aluminum Radiators
  1. motorhead446
    motorhead446 Well-Known Member
    628
    32
    Jul 10, 2007
    LAPORTE, INDIANA
    Local Time:
    6:19 PM
    I have a huge griffin radiator right now. Its a universal fit side tank 3 or 4 core (dont remember). I cannot use a clutch fan. I would like to use a correct size (26")? 2 core radiator in hopes of using the clutch fan with a shroud. an electric fan is not out of the question. The engine is a 493 bigblock, with auto trans that i plan to run in drag week. I do not know the horsepower at this point but we suspect 625 ish. Do you offer something that will work? I do not require correct location mounts and I can even modify( tig weld) the mounts to suit my needs if neccesary. Thanks
  2. famous bob
    famous bob mopar misfit
    19,201
    8662
    Aug 14, 2011
    okla
    Local Time:
    6:19 PM
    Ditch the 3-4 cores , get a two row , 1 1/4 tube --------------
