Biggest tires on my dart
elitesrock2
spokane
I've got a 69 dart custom i'm getting on the road this summer and I'm trying to find the largest tires i can fit under it with super stock springs and factory v8 front suspension. just gonna run normal radial tires will have 15x7 slotted mags
Backspacing (in):3.750 in. Offset:-5.00mm all the way around
Will have a high 11 second small block with a 4 speed
no spring offset or anything as well just stock wheelwells front and rear with super stock springs
Only real way to find out for your car is to measure. All cars are slightly different. 245/60s is my guess.
ran 245/55 on a 69 gts , and home made 15x8's w/225/70 on them for a tall tire on my 69 gt . pic of the gt .
I have 8.5x26" mt pro bracket radials on my race car. They fit fine & hook good. The biggest we could put under the front of my son's 70 Swinger is a 225/60-15
You can fit 275/60 in stock tubs with offset shackles.
Take a look at my build I did on here
