Biggest wheel on an 8 3/4 early A?
Tires and Wheels (Mopar Hubcaps Too)
  1. Matto
    Matto Well-Known Member
    144
    68
    Jul 27, 2013
    Vancouver, WA
    Local Time:
    1:32 AM
    Does anyone know what the biggest wheel and what offset will fit on an A body 8 3/4 with aftermarket 5x4.5" axles with disc brakes on an early A body? Its for my 64 valiant and I was hoping to fit a 15x10" wheel with a reasonable offset, so I don't have to get custom wheels with a huge backspace or narrow my rear housing. I dont have the axles or brakes yet, but I'm thinking of going with Dr. Diff.
  2. Commando66
    Commando66 She's a beaut Clark!
    1,734
    178
    Dec 2, 2007
    Gig Harbor, WA
    Local Time:
    1:32 AM
    Stock spring location? Mini-tubbed? If not, a 15x7. Maybe an 8.
  3. Matto
    144
    68
    Jul 27, 2013
    Vancouver, WA
    Local Time:
    1:32 AM
    Its a 3 link with the bars moved inboard. No mini tub yet, but I'm willing to do that to get a 275/60/15
  4. Commando66
    1,734
    178
    Dec 2, 2007
    Gig Harbor, WA
    Local Time:
    1:32 AM
    You're going to have to mini-tub it. Next thing you will have to look at is the front of the tire contacting the lower part of the fender opening. That's a 28" tall tire and early-a's have a hard time fitting that size without moving the axle back or trimming sheetmetal.
  5. MuuMuu101
    MuuMuu101 Well-Known Member
    1,785
    169
    Jul 6, 2012
    SoCal
    Local Time:
    1:32 AM
    I've got the same rear end setup with leaf springs on my '68 Dart and I don't think I'd be able to fit anything larger than a 9" wheel under my stock wheel wells. Granted, I'll be running an 18" diameter wheels so I'll be getting much less tire flex than you will with a 15" wheel. I'll be running 255/40/18's on all 4's.
  6. Matto
    144
    68
    Jul 27, 2013
    Vancouver, WA
    Local Time:
    1:32 AM
    Thanks guys. My lower bars mount to the rms leaf spring boxes, so I can move the rear back if need be.
    Hey MuuMuu101, do you know what offset your wheels are?
  7. toolmanmike
    toolmanmike FABO Staff Staff Member FABO Gold Member
    35,218
    17199
    Jan 18, 2006
    Iowa
    Local Time:
    3:32 AM
    With your non stock combination you will have to measure. You can fit a 15x7 on a stock rear/spring set up with a 4" backspace. With a custom offset wheel may be a 8"wide wheel with a little wheel opening rolling depending on the tire. You have a modified combination that will require you to measure. tmm
    • Like Like x 1
    • WRB426
      WRB426 Insane 4 Mopars FABO Gold Member
      2,237
      173
      Apr 20, 2011
      MA
      Local Time:
      4:32 AM
      I have 275/60R15 on my 64 Dart. Moved the springs in 3". Rolled the qtr lip a little. Still a tight fit. Rims are 15 x 8" with a 4 3/4" backspace.
    • Matto
      144
      68
      Jul 27, 2013
      Vancouver, WA
      Local Time:
      1:32 AM
      So after the mini tub, it seams I'm gonna have to narrow my rear about 3" unless I get a 10" wheel with 7" of backspace, right? I want that deep dished look in the back.
    • breakstuff
      breakstuff Well-Known Member
      828
      73
      Jun 11, 2004
      earth
      Local Time:
      6:32 PM
      I run 28 12.5,s on 15x10,s with 4 1/2" BS. My 65 is mini tubbed to the frame rails with a narrowed 8 3/4
    • Matto
      144
      68
      Jul 27, 2013
      Vancouver, WA
      Local Time:
      1:32 AM
      How much is your rearend narrowed? Width flange to flange?
    • MuuMuu101
      1,785
      169
      Jul 6, 2012
      SoCal
      Local Time:
      1:32 AM
      For my specific car, I got about +18mm for the rears and about a +30mm for the front. The fronts fit perfectly except under full droop and full lock they hit the rear of the frame rail, but I figured I'd never been in that situation for 99% of my driving. The bbp axles and disc brakes pushed the mounting flange out a bit. I still recommend you measure your specific car. I'll be ordering wheels for about the 4th time on Monday. Hopefully this time the wheel won't be discontinued, the distributor won't be lazy and find out if the manufacturer has the wheel, or the manufacturer will actually ship a wheel within ample time.
    • Matto
      144
      68
      Jul 27, 2013
      Vancouver, WA
      Local Time:
      1:32 AM
      SWEET! I just found a local guy that can narrow rearends. What would be a good housing width for an off the shelf 10" wheel. 49"?
    • Keith Mopar
      Keith Mopar Mopar Nut
      2,634
      161
      May 15, 2005
      Calgary AB.
      Local Time:
      2:32 AM
      With stock wheel wells on a 65 Cuda you can fit a 17 X 9 rim, with a 275 tire. I have the springs moved in and the rear end set back 3/4 of an inch to centre the wheel in the wheel well. I have a stock 69 A body 8 3/4 with 4.5 pattern and wildwood disc brakes.
      My rear rims are +24mm with a 5.95 back space.
    • sixty9xtc
      sixty9xtc Well-Known Member
      145
      1
      Apr 3, 2011
      North Dakota
      Local Time:
      3:32 AM
      I have 275/60-15's on my dart with the springs moved in about an inch and I am running 15x8 cragars with a 4 1/8 in back space (this was the most they could do). I didn't have to roll the lip either. It is an extremely tight fit but they work.
    • Matto
      144
      68
      Jul 27, 2013
      Vancouver, WA
      Local Time:
      1:32 AM
      I really appreciate your input everyone! I'm gonna go with a 17" rim later in life for sure, but until I can afford it, a 15" steelie will have to do.
      Feel free to post up some big rimmed early a pics!
    • breakstuff
      828
      73
      Jun 11, 2004
      earth
      Local Time:
      6:32 PM
      I really don't remember
