black rubber mount height differences. 64 dart 273
Rapid Robert
Lincoln Nebraska
are drivers & passenger side mounts the same height? and do you have any part #'s for em? thank you for your time. RR
Motor mounts? You need to be more specific.
The factory part number is 2465508 and is the same for both sides.
I'll look & see what I have. I coulda swore that one was taller than the other but I will go back in there. thanks guys. RR
I've posted this on several header threads
Early short sm blk mount
[/URL]
Interchangeable Taller mounts from newer truck/vans
[/URL]
Good luck .
Well, not quite "early"- that's a '67-'72 mount, OP wants the '66 and earlier number referenced above. The later mount is also frequently incorrectly listed as an early mount in many parts listings. In Rock Auto's listings for example, they have the later number listed for '64-'66 Darts, but the correct early mount listed for the same years Valiant/Barracuda... go figure. But then again, they also list 383 and 413 engines as available in the early Darts- I wish! Buyer beware.
