Anybody know the weight of a bare 360 block. Just block and main caps. I did a search and didnt find it. Cley View attachment 1715431924
IIRC the 360 is 25lbs heavier. whole engines? Mopar Slant Six 475 Mopar 273-340 "A" V8 525 Mopar 360 "A" 550 Engine Weights II
That sounds pretty close. The T/A block is ~ 15 pounds heavier than that, the X block was another 10 and I haven't weighed the R block yet (but I will) is said to be another 20 pounds over the X. So that means: 340/360 is ~ 165 T/A is ~ 180 X block is ~ 190 R block is ~ 210...although that pig feels much heavier than that.
Someone stated the 273 block was lightweight compared to other LA's. I said it probably weighs more. Smaller bores = more cast iron. It depends on what cooling jacket cores they used.
