Blocked Coolant Passanges Head Gasket
Small Block Mopar Engine
  1. seabee
    seabee FABO Gold Member FABO Gold Member
    2,488
    657
    Dec 20, 2009
    Bonita, CA
    Local Time:
    3:16 AM
    Noticed today that SB Head Gaskets block the upper/front coolant passages to the heads from the block. I am sure there is a reason for this. Anyone have an answer?
    [​IMG]
    But the rear/uppers have a passage
    [​IMG]
  2. nm9stheham
    nm9stheham Well-Known Member
    12,089
    3979
    Dec 20, 2013
    Waynesboro, VA
    Local Time:
    6:16 AM
    A lot of holes are put in the block for casting purposes but are the wrong size and wrong place for proper coolant flow. So I suspect those holes are blocked/made small for coolant flow control. The /6 castings and gasket are the same way, with some holes completely blocked off.
    I have also believed that sometimes in engine development, the best coolant flow pattern is not all that well known in a new engine, and changing the head gasket hole arrangement allows for some 're-engineering' of the coolant pattern as experience is gained with a new engine.
    That copper color shore is purty!
    • Like Like x 1
    • Tech857
      Tech857 Well-Known Member
      188
      40
      Jun 29, 2012
      NH
      Local Time:
      6:16 AM
      Those holes are blocked so the coolant circulates through the block, through the heads and out the intake. If they were open the coolant would go in the front of the block and be pushed right out the thermostat with out cooling much.
      • Like Like x 1
      • seabee
        2,488
        657
        Dec 20, 2009
        Bonita, CA
        Local Time:
        3:16 AM
        Thanks guys, I thought coolant routing was the reason, now I know!
      • fishy68
        fishy68 Tyr Fryr's Inc.
        16,586
        967
        Jan 11, 2005
        Central, IL (Hooterville)
        Local Time:
        5:16 AM
        Spot on
      • RustyRatRod
        RustyRatRod I was born on a Monday. Not last Monday. FABO Gold Member
        79,289
        57623
        Jun 7, 2010
        Georgia
        Local Time:
        6:16 AM
        Ford does it the same way.......FWIW, composition heads are not supposed to be coated with anything. Copper Coat is for metal shim type gaskets. I don't think it will hurt anything, but it's not necessary.
      • Rapid Robert
        Rapid Robert Well-Known Member
        1,222
        193
        Aug 6, 2006
        Lincoln Nebraska
        Local Time:
        5:16 AM
        go to www.moparchat.com then scroll down to & click on "circle track chat" then read Sanborns' cooling mods that are in a sticky at the top of the page. Your questions will be answered. It'll take you a spell to get thru it but ABSOLUTELY worhwhile
