Bolt pattern on 7.25 rearend
cocuda
New Member
Any idea what the standard bolt pattern is on a 7.25 rearend.
Seams stock on my 1967 barracuda , 273 auto 235hp car.
If it's on that car, and it's stock, it should be 5 on 4". Start a tape measure from the center of one lug to the center of another lug two lugs away (in other words, skip one lug), and you'll get the center spacing.
Bob
The more accurate way to measure is from the center of one to the edge of a lug two lugs away.
Also, note that there are 5 on 4 1/2" bolt pattern 7.25" rear ends that came on a-bodies 73 up that also had disk brakes.
