booster vaccum ?
Discussion in 'Small Block Mopar Engine' started by Gator77, May 12, 2018.
  1. Gator77
    Gator77 Well-Known Member
    80
    6
    Jan 14, 2017
    Bridgeton
    Local Time:
    2:03 PM
    where should you run booster vaccum ? ported on intake or back of carb.340 street demon carb 750 .484 cam. 2800 stall converters.sometimes it wont idle in gear
  2. nm9stheham
    nm9stheham Well-Known Member
    9,724
    2159
    Dec 20, 2013
    Waynesboro, VA
    Local Time:
    2:03 PM
    Not sure I follow... ported vacuum is not on the intake. Brake booster vacuum connects on the intake manifold, under the carb.
    Is the 'not idling' problem happening when you hookup the booster?
  3. Gator77
    80
    6
    Jan 14, 2017
    Bridgeton
    Local Time:
    2:03 PM
    so i should run vaccum on port on back of carb.i will plug off booster and see what happens.
  4. 67Dart273
    67Dart273 Well-Known Member
    38,303
    5882
    Oct 14, 2010
    Idaho
    View My Photos
    Local Time:
    11:03 AM
    Does not matter. Traditionally they were connected to a vacuum T on the rear runner of the intake
    The carb port is normally for PCV
  5. RustyRatRod
    RustyRatRod Just another dumbass. FABO Gold Member
    47,437
    12411
    Jun 7, 2010
    Georgia
    View My Photos
    Local Time:
    2:03 PM
    Yup. like Del said. Intake for booster and carburetor for PCV.
  6. Gator77
    80
    6
    Jan 14, 2017
    Bridgeton
    Local Time:
    2:03 PM
    ok tryin to get this motor tuned .what else can i look at for idling in gear.i have 12-13 in of vaccum at idle in park.idle set at 900 -1000.timing is at 10btc.
  7. 1969383S
    1969383S FABO Gold Member FABO Gold Member
    3,701
    1180
    Jan 8, 2012
    Cumming, GA.
    View My Photos
    Local Time:
    2:03 PM
    Big cam?
    If not you have leakage somewhere to include the booster as suspect.
  8. 67Dart273
    38,303
    5882
    Oct 14, 2010
    Idaho
    View My Photos
    Local Time:
    11:03 AM
    No, "big cam" NOT NEARLY ENOUGH initial timing. You may need to recurve the distributor. You likely want more like 15 initial OR MORE
    • Like Like x 1
    • Gator77
      80
      6
      Jan 14, 2017
      Bridgeton
      Local Time:
      2:03 PM
      i found problem im running a street demon 750 i found a adjustment under the electric choke .theres 2 slots rite under air fuel mixture screws i needed to close the throttle plates some more.thanks for your help guys.smoken tires and melten asphalt now
    • nm9stheham
      9,724
      2159
      Dec 20, 2013
      Waynesboro, VA
      Local Time:
      2:03 PM
      Good for you! That is an adjustment a lot of guys miss.
    • famous bob
      famous bob mopar misfit
      11,013
      2668
      Aug 14, 2011
      okla
      Local Time:
      1:03 PM
      intake. make sure ur check valve is good.
