Borgeson power steering kit
Suspension, Steering and Chassis
  1. Shmaako
    Shmaako Well-Known Member
    206
    51
    Aug 29, 2016
    Winnipeg, Manitoba, Canada
    Local Time:
    2:20 AM
    bought a Borgeson steering box, pump and hose kit but as you can see, the return line is crazy short and the pressure line was super awkward to hook up. Seemed like the wrong kit! All was ordered at once so....
    Anyone else have issues like this? Can I couple this return line? Or do I need to get different kit? 20200729_183430.jpg 20200728_214308.jpg
  2. kursplat
    kursplat FABO Gold Member FABO Gold Member
    4,306
    3273
    Aug 24, 2010
    so cal
    Local Time:
    12:20 AM
    who did you order from? you can have new lines made but i'd call whoever sold that.
    • Like Like x 1
    • Car Nut
      Car Nut Mopar Master
      8,407
      53349
      Dec 28, 2018
      Trump Train
      Local Time:
      1:20 AM
      My pump return line is pointed to the driver-side, not up, is that the right pump?
      • Agree Agree x 3
      • Northern Grit
        Northern Grit Well-Known Member
        206
        289
        Jul 21, 2020
        Michigan
        Local Time:
        3:20 AM
        Looks like a /6 kit. You could make it work if you cut the clamp off of the return hose and pull the entire hose off the fitting, then get a longer hose same diameter and 2 worm clamps. It will loop way up though and look odd but the return is not pressurised and just needs to flow back into the pump reservoir.
        • Agree Agree x 2
        • Like Like x 1
        • Shmaako
          206
          51
          Aug 29, 2016
          Local Time:
          2:20 AM
          No clue if its the right pump. I assumed they would know. I told them all of my information.
        • A56
          A56 MoPar Affliction
          5,828
          15848
          Jun 24, 2014
          White Oak, N.C.
          Local Time:
          2:20 AM
          That is odd to say the least. Maybe if the the pump were 6 inches lower but that looks wrong. It's even pointing in the wrong direction.
          • Like Like x 1
          • Agree Agree x 1
          • Car Nut
            8,407
            53349
            Dec 28, 2018
            Trump Train
            Local Time:
            1:20 AM
            Who?
            You need one like this.
            • Agree Agree x 1
            • D's Nuts and Bolts
              D's Nuts and Bolts Active Member
              30
              8
              Jul 23, 2020
              Kansas
              Local Time:
              2:20 AM
              This may be a dumb idea, but could you get a tubing bender on it and turn it toward the box? Also how was the install, been thinking about doing the same but it's going to be a tight fit with the headers. Did you have to take the motor out or lift it up?
            • Shmaako
              206
              51
              Aug 29, 2016
              Local Time:
              2:20 AM
              Its pretty tight thats for sure. I ended up installing spacers in the drivers side engine mount to gain the small amount of room needed for clearance. Had everything out anyways so it wasn't any extra work.
              Not finished yet but it seems good so far.
              30
              8
              Jul 23, 2020
              Kansas
              Local Time:
              2:20 AM
              So did you have to unhook the headers, lift the engine, etc?
            • Shmaako
              206
              51
              Aug 29, 2016
              Local Time:
              2:20 AM
              I had the steering box installed, motor installed on the k member and lifted the car up....installed everything from underside. So it was all together when I installed. I had to install the spacers to ensure the extr clearance, but headers were bolted on securely ya
            • BORGESON
              BORGESON Sales/Tech FABO Vendor
              27
              38
              Dec 12, 2019
              South Carolina
              Local Time:
              3:20 AM
              This looks like our #800326 power steering pump that we would include on a Chrysler LA small block pump kit that mount the pump much lower on the drivers side. We use a different pump pulley and reservoir for big block applications, on the big block pump the return tube exits the center and points down.
            • Shmaako
              206
              51
              Aug 29, 2016
              Local Time:
              2:20 AM
              So you believe I have the proper hoses but the wrong pump.
              Would you happen to have the part number for the proper pump?
            • BORGESON
              27
              38
              Dec 12, 2019
              South Carolina
              Local Time:
              3:20 AM
              The Saginaw pump with pulley for Big Block Mopar applications is our part #800321, we also offer it as a pump, bracket and pulley kit under #800338 however since you have the brackets you would only need the pump with pulley #800321
              • Thanks! Thanks! x 1
              • Mike69cuda
                Mike69cuda 66 is the new 17 FABO Gold Member
                2,699
                2255
                Jan 2, 2018
                Overland Park Kansas
                Local Time:
                2:20 AM
                I think the output (high pressure ) is in the the same Place on all Saginaw pumps. The return line is bent different ways depending on application. If you just use a longer return hose (about $5), it should work fine. Might not look as good with the top exit the way you have it. You can also change the tin pump housing if you have another one. I think all the Saginaw pumps fit in all the housings. Seems a shame to have to buy another whole pump for that.
                • Agree Agree x 1
                • kursplat
                  4,306
                  3273
                  Aug 24, 2010
                  so cal
                  Local Time:
                  12:20 AM
                  i don't know why he would have to buy a new one, return for the correct one or just re-plumb the one he has. i'd probably just bend the tube like D's said. but it's jacked up you had to mess with spacers to get it to work
                • BORGESON
                  27
                  38
                  Dec 12, 2019
                  South Carolina
                  Local Time:
                  3:20 AM
                  He only needed spacers due to it being a small block pump/pulley, the big block Mopar pulley has a different offset that pushes the pulley further away from the pump. Give our office a call you can send that whole pump/pulley in and we can swap it for you.
                  • Like Like x 3
                  • kursplat
                    4,306
                    3273
                    Aug 24, 2010
                    so cal
                    Local Time:
                    12:20 AM
                    the best fix
                    • Like Like x 1
                    • Agree Agree x 1
                    • Shmaako
                      206
                      51
                      Aug 29, 2016
                      Local Time:
                      2:20 AM
                      I really appreciate your willingness to help me out here!
                      Unfortunately, I purchased the Borgeson pump, steering box, and hose kit from Summit Racing. It was their mistake as I ordered the correct one for a 383BB.
                      I finally got a hold of them today after an hour of listening to elevator music recorded voice messages, and I was promised to get a call back tomorrow morning. She said she was going to call Borgeson and see what they said. (I told her what you said)
                      I live in Canada so I want to ensure that shipping will not be an issue for an exchange item. I do not feel it should be my responsibility...I paid the first time lol
                    • BergmanAutoCraft
                      BergmanAutoCraft FABO Vendor FABO Vendor
                      288
                      236
                      Feb 18, 2013
                      Long Island, NY
                      Local Time:
                      3:20 AM
                      My kit uses factory hoses, factory style bolt on pullies! I'm a site sponsor too.
                      • Like Like x 2
                      • Shmaako
                        206
                        51
                        Aug 29, 2016
                        Local Time:
                        2:20 AM
                        I can now see the value in ordering straight from Borgeson or other site sponsors like Bergman due to their knowledge on our specific vehicles...live and learn.
                      • supertruck
                        supertruck Unretired Old Fart stock car racer FABO Gold Member
                        745
                        398
                        Feb 14, 2016
                        Gloucester, Va
                        Local Time:
                        3:20 AM
                        FWIW, I bought the Borgeson kit for the LA in my 73 Sport from the member on here. Everything fit but I did have to do a fair amount of bending on one hose to get clearance and fit the pump.
                      • Shmaako
                        206
                        51
                        Aug 29, 2016
                        Local Time:
                        2:20 AM
                        UPDATE
                        After I told them that Borgeson had offered to swap the pump, they said I should do that. I didn't feel right about having Borgeson dealing with their mistake. They had no choice but to agree, so they said they would replace it, no problem. Now it has been a number of weeks and I contacted them only to find out they were no longer willing to send me the 800321 pump without me paying them $70.80 the difference between BRG-800338 and the small block pump they originally sent me. I informed them that the pump I want is the 800321 which is the same price, but as per their site, it is no longer available?? Unfortunately for me, I purchased three brackets locally trying to make the pump they sent me work so I do not need the BRG-800338 kit.
                        I am so frustrated with Summit!!
                        First they send the wrong pump. Then I pay to ship it back. Now they go back on their word.
                        So silly. Over a $200 pump, from an order for which I ordered with a few thousand dollars of product.
                        And still no pump...
                        #Summitsucks
                      • Car Nut
                        8,407
                        53349
                        Dec 28, 2018
                        Trump Train
                        Local Time:
                        1:20 AM
                        That’s odd, did you order the pump online or over the phone?
                      • GMachineDartGT
                        GMachineDartGT Senior Member
                        1,621
                        296
                        May 9, 2006
                        Huntington, NY
                        Local Time:
                        3:20 AM
                        Sorry for your troubles. The good thing about being small is you can handle things quick. I’m also available almost any time. Live and learn.
                        • Like Like x 1
