1. DusterDaddy
    DusterDaddy sledgehammer mechanic FABO Gold Member
    2,370
    1444
    Apr 21, 2011
    Holmdel, NJ
    Local Time:
    9:05 AM
    I just installed a Borgeson power steering box in my 74 Duster.
    Summit sent the box for 72 that has the smaller 1-1/8 pitman shaft
    Will a pitman arm for a 72 work in my otherwise stock 74 steering setup?
  2. *Pentastar
    *Pentastar New Member
    3
    2
    Jan 6, 2011
    Leppävesi
    Local Time:
    4:05 PM
    No 72 armpit wont fit. Use 74 manual steering pitman arm MOOG K7075
    • Like Like x 1
    • Agree Agree x 1
    • DusterDaddy
      2,370
      1444
      Apr 21, 2011
      Holmdel, NJ
      Local Time:
      9:05 AM
      Thanks men, got the 74 manual pitman arm and it’s going back together...
      • Like Like x 2
      • MileHighDart
        MileHighDart Well-Known Member
        3,532
        2381
        Jun 3, 2004
        Lyons, CO
        Local Time:
        2:05 PM
        Let us know how you like the box when it’s back on the road.
      • DusterDaddy
        2,370
        1444
        Apr 21, 2011
        Holmdel, NJ
        Local Time:
        9:05 AM
        A034408B-93CA-43E8-A404-F851A8240F7F.jpeg 3D3DDF7F-17E9-443B-BF92-8BD73DE0ACA9.jpeg Ok men. The car is back on the road and man oh man, the box gives you great feel of the road at about the firmness of a modern Challenger.
        I am running stock V8 torsion bars, stock suspension with all Moog parts, along with a Hellwig sway bar.
        Only departure from the norm are the coil over front shocks that are normally run on Ford ranger pickups. The car stays nice and flat in the corners. A bit unconventional but it works great for me. They were a tip from the local Chrysler guru...
        • Like Like x 4
        • BigBlockMopar
          BigBlockMopar BigBlockMember
          1,714
          708
          May 1, 2011
          Netherlands
          Local Time:
          3:05 PM
          The coil-overs just help the torsion bars do their job, which also shows that larger torsion bars (increased springrate) pretty much always improve ride quality and (even normal) handling.
          The Borgeson costs a bit of money but is well worth it and brings an old car's steering control up to a whole new level.
        • MileHighDart
          3,532
          2381
          Jun 3, 2004
          Lyons, CO
          Local Time:
          2:05 PM
          Thanks for the update
        • swinger1969
          swinger1969 Repeat Mopar guy
          147
          32
          May 2, 2015
          Victoria, BC Canada
          Local Time:
          6:05 AM
          What ratio is that box?
        • clementine
          clementine Flight risk FABO Gold Member
          566
          223
          Jan 3, 2016
          Emerald city
          Local Time:
          6:05 AM
          wait a sec.....You are running coil overs AND torsion bars? Did I miss something? I love the idea, and like to know how to do that. What are the attachment points? Is it the same as just going to a 1.03 torsion bar?
          Thanks!
        • DusterDaddy
          2,370
          1444
          Apr 21, 2011
          Holmdel, NJ
          Local Time:
          9:05 AM
          Father-Son 1974 Duster Project
          See post 2112
          They are just coil over shocks.Also see post 5 in this thread above. Got the idea from an old timer at the local garage. They make a difference with the stock V8 torsion bars and I think they look cool too.
          • Thanks! Thanks! x 1
          • DusterDaddy
            2,370
            1444
            Apr 21, 2011
            Holmdel, NJ
            Local Time:
            9:05 AM
            14 to 1
          • Kern Dog
            Kern Dog Well-Known Member
            3,399
            3923
            May 23, 2010
            Granite bay CA
            Local Time:
            6:05 AM
            What year of an armpit fits best? Should the armpit be shaved or is a hairy one okay?
            • Like Like x 1
            • clementine
              566
              223
              Jan 3, 2016
              Emerald city
              Local Time:
              6:05 AM
              Its only OK if we have camped for 4+ days. or road tripping.......to a grateful dead show.
              • Agree Agree x 1
              • 72bluNblu
                72bluNblu FABO Gold Member FABO Gold Member
                9,672
                3855
                Nov 28, 2008
                NorCal
                Local Time:
                6:05 AM
                I can sort of understand doing something like this in the seventies or eighties when there wasn’t very many options for upgrading the woefully inadequate stock torsion bars. But there’s no reason to do it now.
                Do it right, buy a set of 1.03” (or bigger!) torsion bars. You’ll actually know what your wheel rate will be, you can match your shocks to the wheel rate of your torsion bars, and you’re not putting additional loads on the shock mounting points.
                That way you won’t have some goofy light truck spring-over-shock fighting with the stock torsion bars for control of your car. They’re a band aid for the trucks, and they’re a band aid and the wrong application for our cars. As for how much spring rate they add, who knows? Gabriel says their rear shocks can add as much as 500 lbs of “load capacity”. What that translates to in spring rate depends on what they actually mean by that. The fronts are supposed to be a constant rate, the rears are variable. But they’re just a band aid to keep your stock suspension from sagging. Even the trucks would be better off without them. If you need these things, what you actually need is new springs that match what you’re doing with your vehicle.
                • Agree Agree x 1
                • DusterDaddy
                  2,370
                  1444
                  Apr 21, 2011
                  Holmdel, NJ
                  Local Time:
                  9:05 AM
                  Nothing fights with anything in my car. It’s all peace, harmony, and love.
                  Thanks for your concern, but she drives great and is a dream come true to me...
                • MileHighDart
                  3,532
                  2381
                  Jun 3, 2004
                  Lyons, CO
                  Local Time:
                  2:05 PM
                  Well, hairy is more "natural" if you're into that sort of thing. But I like mine shaved cause, that's how I roll.
