Looking great, those are really cool linkage pieces.Got some solid time in the shop on Sunday with punk rock cranked up to keep the energy high. The pan is now in place, and I fully welded the tail panel for added strength instead of relying on spot welds. Installed the rear down bar plates, cleaned up unnecessary stampings around the taillight mounts, and filled the lock hole. I also tackled some rust repair under the rear window.
Decided to cut out the upper section of the pan to replace it with a removable aluminum panel for easy access to the fuel pumps. Next steps include fabricating the frame for the pump section and tying up a few loose ends. The goal is to have the down bars finished and the rear remounted on the rotisserie by the end of the week.
My garage is the same temp as yours 34° , it's a pain in the *** to work In that so good job.
