Brake Booster swap
AdamR
Big Member
Bethel, CT
Anyone know if I can use a 73 and later brake booster on my 71 Dart ? The 70-71 booster is not available, the 73 and later is easier to find.
as far as the use of the later booster. you will need to check out the mounting brackets as they are probably different which would make the pedal sit either further in or out depending.....
oh yeah that is the 73 and up style. if the brackets are original you are set!
