Yall help me out with a brain fart. Some of you may remember, I converted my 64 Valiant, Vixen to a tandem manual disc brake master cylinder a while back. It's the master cylinder where the front and rear reservoirs are the same size. If memory serves me correctly, I think it's the same drum to disc and the difference is the proportioning valve. Regardless of that part, I cannot remember which port is for the rear brakes. Is it the front port or the rear? Thank you drive through.
