Hi all. Had Friday and Saturday Races this weekend at New Oxford Dragway in Oxford, Maine. Had a great Friday night taking the win Top ET ( Super Pro). Saturday I was running two classes, Box and 5.80 index with the Gassah Guys Club. Took the win in the 5.80 class but had to bow out after 3 rounds in Box. I had noticed in the round before that when getting on the brakes after the finish line that the pedal felt firm initially but then would get soft and eventually get really soft. After the 3rd round in Box I thought I was going to go into the sand trap but had enough brake to get slowed down enough to make the turn on the return road.
The basic info on my brake system is a Wilwood tandem master cylinder, and Aerospace Components brakes front and rear. Being a full chassis car, the master cylinder is mounted on the left frame rail just forward of the drivers seat. I replaced both residual pressure valves and the manual bias adjuster this past winter, along with new pads front and rear. Brakes felt and worked great prior to Saturday. Did some troubleshooting today and it appears that the master cylinder isn’t moving much fluid. If i pump the pedal three or four times it is firm initially but if I continue pressure on the pedal it goes all the way to the firewall. I checked for leaks and there are none. I’m thinking the master cylinder has gone bad. Anyone have any other ideas?
