Brake line vendors
Captainkirk
Old School Mopar Warrior
Northern IL
I was considering replacing all the brake lines on my '72 Duster during the restoration, as pre-bent and fitted lines were available from Classic Industries. Now people are saying to avoid them like the plague. Anyone have another source they've used, and what did you think of them? (fit, etc)
Just curious...why no SS?
They don’t seal as well, I made a mistake purchasing stainless steel the first time. If the flares are off and/or the harder metal, it takes a while for them to seat, you gotta keep backing the nut off and on.
There is a post somewhere here that detailed these little copper ferrules that they use in HVAC. I guess they call them flare gaskets. Use those as crush washer and the SS will seal just fine. I got my preformed lines from Cass @ DoctorDiff
I bought fuel and brake lines from Inline Tube, don’t buy stainless steel.
Why not stainless? I bought their stainless for all my lines on the 66 and they have been great. (Knock on wood.)
I also avoid stainless, but if you DO go with stainless, I highly recommend using copper flare gaskets. They will make your life much easier.
eyJ3aWR0aCI6ODAwLCJoZWlnaHQiOjYwMCwiZml0IjoiY29udGFpbiIsIndhdGVybWFya2VkIjp0cnVlLCJrZXkiOiJhc3...jpg
righty tighty, where do they sell those copper flair gaskets and what size would a Duster owner need, asking for a friend.
I get mine from Grainger, but if you search online, I'm sure you can find many vendors. They're sized according to whatever size line you're working with, so 3/16"? I'll confirm once I get to the shop.
A tip for installing them: I dab a very tiny amount of Permatex High Tack to keep it in place, otherwise they like to jump out at the worst moment. And they're not cheap, so losing two or three in the engine bay sucks.
Whats wrong with the pre made ones as was just about to purchase thinking would save a lot of time
Right before Covid I ordered something from Classic that was listed as in stock. Took 9 months to get it. That's the last time I'll order from them.
