Flyinbrian72duster
Dart and duster
Just looking for input pretty sure I need new brake lines 71 dart all drum with power. New master n booster n front shoes and wheel cylinders how I bought it and who ever put this line on lol.
There's a little drag down but more so after a stop I take my foot off brake and car sits wont idle away and it seems it gets worse the hotter I get themJust looking for input pretty sure I need new brake lines 71 dart all drum with power. New master n booster n front shoes and wheel cylinders how I bought it and who ever put this line on lol. View attachment 1715244344
Is there a spec for thatCheck push rod on power booster might be to long and need to be adjusted back a bit. IF too long it puts pressure on master causing that issue.
I made it about 1/16" from booster push rod to the center of piston hole on master. I used a tool to get it right but not necessary.Is there a spec for that
Second on this. I'd start with the brake hoses, they're maybe $15 each at any parts store. Two for the front, one for the rearRubber brake hoses will do that when they get old and wore out. You push the brake,when you let off that rubber collapses and holds pressure still to the wheel cylinders....
