Hankrebel
71 Swinger 318 with AC
Edelbrock Performer and Eddy 4bl carb
The stock breather cap has 3 ports.
1 for the fuel line
1 that went to the air cleaner
1 that went to the top of the 2bl carb
There is already a PCV on drivers side valve cover that's going to main inlet on carb
Do I really need the port for the air cleaner or carb any longer?
If not I can just install a newer 1-port breather
Also with the above setup, will a 10 inch diameter air cleaner with 2 inch filter have enough hood clearance?
1 for the fuel line
