brightest head lights
Discussion in 'Electrical and Ignition' started by mopardemon340, May 8, 2018.
  1. mopardemon340
    mopardemon340 Well-Known Member
    500
    30
    Aug 10, 2015
    WI
    Local Time:
    12:50 PM
    what headlights are the brightest. looking for LED, HM, or HM bulbs and replace able lenses.
    also how do i align them
  2. diymirage
    diymirage HP@idle > hondaHP@redline
    14,326
    6602
    Oct 12, 2012
    michigan
    Local Time:
    1:50 PM
    the ones that run through @crackedback 's relay wiring
    or do a search for @slantsixdan , he recomends some great sealed beams, something with a birdy, nighthawk, roadeagle, something or another
    • Agree Agree x 2
    • Thanks! Thanks! x 1
    • SSVDP
      SSVDP FABO Gold Member FABO Gold Member
      3,759
      2670
      Feb 6, 2009
      Clarksville, Tn
      Local Time:
      1:50 PM
      • Agree Agree x 1
      • crackedback
        crackedback FABO Gold Member FABO Gold Member
        17,972
        1955
        Aug 7, 2005
        92201
        Local Time:
        10:50 AM
        Lots of choices in lights. For a low dollar sealed beam single headlight GE H6024NH nighthawks. Those are the ones I recommend with my relay kits when $ matter.
        There are a lot of not so great lights in the HID/LED arena. If you buy those, make sure they are good ones.
        • Like Like x 1
        • Agree Agree x 1
        • Mopar to ya
          Mopar to ya Well-Known Member
          3,052
          124
          May 17, 2011
          North Branch, Minnesota
          View My Photos
          Local Time:
          12:50 PM
          I use Hella conversion lights with an H4 bulb with a higher wattage high beam. I used Slansixdan's relay kit, but have had a fallout with him, and I like crackedback much better. My next relay kit will be from him.
        • mopardemon340
          500
          30
          Aug 10, 2015
          WI
          Local Time:
          12:50 PM
          What size hella conversion light?
        • mopardemon340
          500
          30
          Aug 10, 2015
          WI
          Local Time:
          12:50 PM
          what size hella kit did you need. 165, or 178
        • lilnoah
          lilnoah Supercharged slant six with 4 speed and 8.25 FABO Gold Member
          427
          139
          Dec 22, 2014
          Murfreesboro, TN
          Local Time:
          12:50 PM
          I used JW Evolution LED
        • 1963dartgt
          1963dartgt Well-Known Member
          502
          142
          Nov 7, 2015
          CA
          Local Time:
          12:50 PM
          I have the cibie conversion lights with headlight relays and some sylvania xtravisions. I drive 30 miles at 75mph down I70 for work at 3 in the morning in deer country. I like my headlights to work With my brights on i can light up damn near both sides of the interstate.
          • Like Like x 3
          • rustycowll69
            rustycowll69 Well-Known Member
            1,608
            592
            Feb 19, 2016
            Pacific northwest
            Local Time:
            10:50 AM
            As far as H4, the best beam I've ever had came from a Cibie. Love their Z- beams. But I don't know if they are even in business anymore. yeah, you really need to run a relay like others have suggested.
            • Like Like x 1
            • RustyRatRod
              RustyRatRod Just another dumbass. FABO Gold Member
              47,437
              12411
              Jun 7, 2010
              Georgia
              View My Photos
              Local Time:
              1:50 PM
              I have had both the Cibie H4 E code conversion and the Hella. I have the Hella E code conversion now in my 75 F250. Other than the difference between the wattage bulbs...I had 100/90 in the Cibies and 65/55 in the Hellas, the light shape and cutoff is the same. I plan to upgrade to the 100/90 soon.
            • Mattax
              Mattax Just the facts, ma'am FABO Gold Member
              4,493
              2303
              Feb 7, 2013
              Phila. Pa
              Local Time:
              1:50 PM
              Cibie is in business. There's just very few retailers in the US. But the Z-beams are no longer produced so are hard to find.
              With any H4 lamp assembly, the design and quality of the housing and the bulb can make a big difference on whether the light produced is effectively placed on the road. And IMO, there are also personal preferences based on things like where you drive and how tolerant your eyes are for contrast and things like that. Living in a part of the country with lots of wooded twisty roads and undulations puts a slightly different priority on things than the high desert. Anyway my point was even a good lamp will not perform well with a poor bulb. "Hilldweller" did some comparison measurements of lumens at set locations on the road using the same Hella lamps and two different bulbs. With the Delta Blue 'Xenon' bulb it wasn't much better (in lumens at the test locations ) than a plain old sealed beam. His tests also showed a couple of the new LED lamps are very good. Personally I don't like the contrast, but they are bright, and legal. The good ones are not cheap.
              chart and links 1/2 way down this page: Headlights
              Aiming
              For a single pair of combined Hi/low lamps, aim them using the low beams. (The high beam instructions are for cars that have a dedicated pair of high beam only lamps.)
              For DOT or SAE marked headlight aiming without a machine.
              For lamps made to European Commission standards, use E-code headlight aiming
              • Like Like x 1
              • Mopar to ya
                3,052
                124
                May 17, 2011
                View My Photos
                Local Time:
                12:50 PM
                • Like Like x 1
                • rustycowll69
                  1,608
                  592
                  Feb 19, 2016
                  Pacific northwest
                  Local Time:
                  10:50 AM
                  I always figured the French(Cibie) just knew more about optics than most, because lighthouses used to have French made lenses. Did not know the bulbs made much difference, other than wattage. Maybe that explains why I wasn't as impressed with Hella's.
                  Don't want to hijack thread, but does anyone know where you can find the wire baskets to protect the H4 lenses? They used to be more common, I don't know where you can get them, now.
                • Mattax
                  4,493
                  2303
                  Feb 7, 2013
                  Phila. Pa
                  Local Time:
                  1:50 PM
                  Yes. I also was surprised it can have noticible effect. It happens I currently have a Hella Vision plus and a Cibie E-code on my wagoneer (rectangular type) with Hella's supplied bulb in the one, and a Narva Rangepower +30 in the other. But I haven't had a chance to really aim them properly and then go measure lux with a light meter. When I do, then I'll switch the Hella bulb to a Narva +30 and retest and see if there is a measurable and visual difference. Both are rated 60/55W power draw.
                  A super techie comparison of 4 bulbs in 2 slightly different lamps, one to a US standard, the other made to an ECE standard.
                  Interesting headlight bulb test results
                  I hunted down some z-beams a couple years ago for the Barracuda but haven't installed them yet. There's certain places I drive where I really want them, that's when they'll go in. At the time I did see metal grill stone guards, but don't recall where. Sorry. For auxillery lights, most people keep them fully covered until needed. Having had a fog light lens crushed, I've come to accept that's a smart move.
                  Only stuff here looks like is for only for auxillary lamps. Not sure if it would attach to the headlamps. May depend on the surrounding retaining ring and trim..
                  RallyLights.com
                • rustycowll69
                  1,608
                  592
                  Feb 19, 2016
                  Pacific northwest
                  Local Time:
                  10:50 AM
                  the headlight lens screens I remember seeing many years ago, we're chromed and clipped on so that they could easily be removed for lens cleaning. I am leary to expose my remaining cibie's to a stone. That has happened twice before.
                  • Agree Agree x 1
