I've got a question about my broadcast sheet for my 70 Duster On line 2 under axle it says D53 which I believe means 3.23:1 diff. Then on line 4 under axle it says 019. Is that maybe the code for the housing? Thanks in advance!
Thanks for the replies! Here is some more info. The first picture shows axle code D53 which I believe means 3.23:1 gear ratio and just left of that is a one in the box under D91 S/G that i assume is a Sure Grip code. The second picture shows the other axle code. It is hard to read, but I think it says 019.
Probable because you don't have sure grip and/or your brakes are a different size, it is an assembly code (actually the last three digits of the assembly part number). Alan
