Broken bolt in head
Small Block Mopar Engine
  1. Dennis Gerard
    Dennis Gerard Well-Known Member
    293
    75
    May 7, 2017
    Florida/tenn
    Local Time:
    5:22 PM
    My 30 min job turned into a nightmare, went to put on my new valve covers today, Did drives side now problem went to passengers 4 bolts came right our then 5th seems like it was broken off by someone and they used a ton of silicone on it. To make it worst after close inspection there may be a broken easy out in it.
    Any suggestion or is it machine shop time.
  2. ch1ll
    ch1ll FABO Gold Member FABO Gold Member
    776
    276
    Jun 12, 2009
    Belgium,wi
    Local Time:
    4:22 PM
    If you’re in the Milwaukee area, bring it over. I’ll get it out.
    • Like Like x 1
    • Treblig
      Treblig Well-Known Member
      6,499
      3673
      Oct 5, 2013
      South Texas
      Local Time:
      4:22 PM
      Can you post a close "clear" pic. I'm a machinist.
    • ch1ll
      776
      276
      Jun 12, 2009
      Belgium,wi
      Local Time:
      4:22 PM
      51265A28-71E1-4B94-B19E-B0AF6411620C.jpeg Pardon the dust, just finished tuck pointing the inside of the shop.
      • Like Like x 2
      • Northern Grit
        Northern Grit Well-Known Member
        168
        217
        Jul 21, 2020
        Michigan
        Local Time:
        5:22 PM
        You might be able to bust up the easy out with a punch then vacuum out the crumbs.
        • Agree Agree x 1
        • rustycowll69
          rustycowll69 Well-Known Member
          2,299
          1075
          Feb 19, 2016
          Pacific northwest
          Local Time:
          2:22 PM
          I've done that on big holes, but I'm not sure that would work very well on small holes like for v. cover fasteners.
        • Treblig
          6,499
          3673
          Oct 5, 2013
          South Texas
          Local Time:
          4:22 PM
          Doesn't look too bad. If it is an easy out you can get a center punch and a smaller hammer and attempt to make the easy out "back out" by gently punching it in the opposite direction. Make sure you go the right direction and at right angles. If it's a tap then use a punch to carefully bust it up (they are brittle). You'll need a pick or a scribe to pick out the pieces as you go.
        • oliver
          oliver Well-Known Member
          444
          121
          Jan 12, 2011
          Vallejo, CA
          Local Time:
          4:22 PM
          That oil looks kinda milky.
          • Agree Agree x 5
          • Treblig
            6,499
            3673
            Oct 5, 2013
            South Texas
            Local Time:
            4:22 PM
            I saw it too but didn't want to say anything.....one problem at a time.
            • Agree Agree x 1
            • Daves69
              Daves69 Well-Known Member
              5,199
              3397
              Feb 20, 2011
              WestOfChi
              Local Time:
              4:22 PM
              Small flat washer and nut weld trick?
              Does all you oil look like that?
            • Treblig
              6,499
              3673
              Oct 5, 2013
              South Texas
              Local Time:
              4:22 PM
              If you have a carbide burr you can also carefully grind away the broken easy out or tap.
            • Dennis Gerard
              293
              75
              May 7, 2017
              Florida/tenn
              Local Time:
              5:22 PM
              it is but from when I was working on water pump and power steering ...was going to change it next
            • Dennis Gerard
              293
              75
              May 7, 2017
              Florida/tenn
              Local Time:
              5:22 PM
              This is the car 318 auto
              • Like Like x 10
              • oliver
                444
                121
                Jan 12, 2011
                Vallejo, CA
                Local Time:
                4:22 PM
                Oh. Did some coolant run into the oil or something and mix?
              • Dennis Gerard
                293
                75
                May 7, 2017
                Florida/tenn
                Local Time:
                5:22 PM
                Yes had bolts out to put in new bracket for power steering, other then thatcar has not run
              • Tooljunkie
                Tooljunkie King of cobble/master of the broken bolt FABO Gold Member
                16,372
                16219
                Jul 22, 2017
                Manitoba
                Local Time:
                4:22 PM
                Carbide burr will get it out, but may end up oversize. I have watched videos of guy with tig, built it up and threaded the bolt out with a vise grip.
                • Like Like x 1
                • rklein383
                  rklein383 Well-Known Member
                  1,581
                  503
                  Dec 2, 2005
                  Local Time:
                  4:22 PM
                  Even if you end of oversize, you put in a threaded insert or even helicoil it and will be a great fix. Very little stress on valve cover bolts.
                  • Agree Agree x 2
                  • JBurch
                    JBurch FABO Gold Member FABO Gold Member
                    1,859
                    996
                    Oct 17, 2009
                    Owego, NY
                    Local Time:
                    5:22 PM
                    Another possibility...........do you have access to ox-aceltline? Line the cutting tip up on the easy out, get it good and hot, then blow it, the easy out, out. Torch will not cut the cast iron of the head.
                  • diymirage
                    diymirage HP@idle > hondaHP@redline
                    21,094
                    15956
                    Oct 12, 2012
                    michigan
                    Local Time:
                    5:22 PM
                    Seems like I JUST read this exact same problem on here, dont think it was over a week ago
                    • Agree Agree x 3
                    • jimjimjimmy
                      jimjimjimmy lobsterman FABO Gold Member
                      4,499
                      1300
                      Nov 2, 2010
                      p. e. i.
                      Local Time:
                      6:22 PM
                      5-32" X-TRACTALLOY BROKEN BOLT EXTRACTION ELECTRODE - Partsmaster
                      use these , you can gently build the stud up with these rods or you can lay a nut over top and weld through the nut until filled with weld and turn out . even if a stud is broke off down deep in a hole you can still use these as the flux fills the threads and protects them from the filler . i use these now for 25 years and never had one defeat me yet . i just pulled 4 broken off flush exhaust manifold studs from a 4.8 dakota a few days ago .
                    • RammerJammer75
                      RammerJammer75 Well-Known Member
                      776
                      956
                      Aug 28, 2020
                      Kingsport, TN
                      Local Time:
                      5:22 PM
                      I got deja vu reading this thread.
                      • Agree Agree x 2
                      • diymirage
                        21,094
                        15956
                        Oct 12, 2012
                        michigan
                        Local Time:
                        5:22 PM
                        Right down to the silicone
                        • Agree Agree x 1
                        • RustyRatRod
                          RustyRatRod Bla de blizhibliz de blatde blizi bla bla
                          66,070
                          39448
                          Jun 7, 2010
                          Georgia
                          Local Time:
                          5:22 PM
                          Well, it's been drilled before and off center. So that's also an issue. If you can get it out, I do believe drilling it for a heli coil and installing a heli coil will fix it though. It looks like there's enough left for that. It's gonna be a challenge.
                        • JDMopar
                          JDMopar Well-Known Member
                          3,454
                          2341
                          Jan 19, 2012
                          Candler, NC/Myrtle Beach, SC
                          Local Time:
                          5:22 PM
                          Tape up that transmission dipstick tube if you ain't done it already! :eek:
                        • pishta
                          pishta I know I'm right....
                          18,685
                          8146
                          Oct 13, 2004
                          Tustin, CA
                          Local Time:
                          2:22 PM
                          Got a plasma cutter? I like the oxy method. blow the molton stuff out! Tried mig'n a nut on a busted stud, no penetration to the nut. Probably didnt do it right.
