Building a 77 motorhome 440
I'd just go with stealth heads airgap headers and 225 ish cam with .480-.500 lift, and it makes what it makes.
Yeah, and with low compression, it's cheap to feed and will never give a single problem.
I had a New yorker Short block refeshed with template ported 906s , 6 pak , headers and a small solid roller . It made505 hp. A stroker with a better port job , good single plane and a more aggressive cam would easily hit 600.
That engine builder [Jim] from Idaho proved you can can make good power with a motor home 440. There is a long thread out there where he did dyno testing. Get a set of heads, spec a camshaft,SD intake, headers and run it.
Well I created my own problem when I built my 440 30+ years ago. Bought the wrong pistons, yada, yada. CR was 9.2. Iron heads with bowl blending, 292/.509 purple cam, 750 vacuum Holley. At least it had an old double plane intake (CH4B). 3200 stall converter with 4.10 gears.
But even this mismatched set of parts and low CR pushed my hefty (4400#'s at the line with me in it) 69 Charger to mid-12's. My learning was to measure things BEFORE you buy parts to get the proper CR!!:BangHead: Heck, this engine even used 87 octane pump fuel!
So don't underestimate the 440 the OP has. They can still run well.
