DesertRat
Leading edge boomer
After pulling my Harmonic balancer to remove the timing cover and do the oiling mods for the timing chain I needed a way to reinstall the harmonic balancer. After thinking about it I went to my bolt vendor and bought a 3/4 X NF grade 8 bolt 5 1/2" long, 2ea 3/4" grade 8 flat washers and a 3/4" NF hex nut. As the bolt had only 2 inches of thread I took it to my machine shop and had them cut NF threads up to the head on a lathe. Searching my parts pile, I found that the outer spindle bearing was a perfect fit for a 3/4" bolt. Cost, nut, bolt & washers $3.85. Lathe work $30.00 and bearing free as I had it in stock. Below are the photos.
DR--------------
DR--------------
