Butt weld panel gap
Mopar Body and Trim
  1. bob7four
    bob7four Well-Known Member
    99
    10
    Feb 8, 2016
    New Jersey
    Local Time:
    12:26 PM
    Have a new patch panel fitted up and ready to weld. I flanged the edge of the existing panel and laid the new panel in. My question is what kind of gap should I have between the panels? The gap seems tight so the panels were fit perfectly. Is there tolerances either way? What is too tight and what would be too large?
  2. cudascott
    cudascott wish I had a Hemi
    1,591
    446
    Jan 11, 2012
    TN
    Local Time:
    12:26 PM
    The gap should be close to thickness of the wire your welding it with.
    • Agree Agree x 2
    • mopar head
      mopar head Well-Known Member
      2,766
      489
      Oct 21, 2008
      Right here, can`t you see me?
      Local Time:
      11:26 AM
      No gap on a flange lap.
    • Dartnut
      Dartnut Don't hate me because i'm beautiful
      10,720
      3018
      Apr 19, 2007
      Southern Alberta
      Local Time:
      10:26 AM
      It sounds like to me that the panel was laid inside of the flange, is that correct?
      That would make it a lap weld, not an open butt weld.
      If this is the case, then the metal where it touches should be flush, and the area where the new panel and the old panel meet at the step should be no more than 1/4'' all of the way around.
      If it is a butt weld, then a gap of about the same size as the wire you are welding it with is the best choice.
      Remember to weld using a series of tacks spaced a foot or so apart and allow for cooling as you go to reduce warping.
      The actual welding takes a long time this way, but it's worth it in the long run.
      Pictures of your project close up would go a long way here......
      • Agree Agree x 4
      • RustyRatRod
        RustyRatRod Bla de blizhibliz de blatde blizi bla bla FABO Gold Member
        59,911
        31005
        Jun 7, 2010
        Georgia
        Local Time:
        12:26 PM
        You're speaking of two different welds in one sentence. Is it a butt weld or a flange weld? The butt weld requires a gap. The flange weld does not. Which is it? It can't be both.
      • bob7four
        99
        10
        Feb 8, 2016
        New Jersey
        Local Time:
        12:26 PM
        Flange weld... excuse my ignorance. Not all experts here. The edge of the new panel is close to being tight against the top of the flange.
      • RustyRatRod
        59,911
        31005
        Jun 7, 2010
        Georgia
        Local Time:
        12:26 PM
        Ok. The way "I" weld a flange weld is like the factory did it. I drill holes through the flange and then spot weld to whatever metal the fanged panel is going on.
      • 66jim
        66jim Well-Known Member
        470
        439
        Dec 11, 2007
        NE PA ie pennsyltucky
        Local Time:
        12:26 PM
        Make sure to address the inside edge of the flange as moisture and debris can collect
        and rust.
        • Like Like x 1
        • RustyRatRod
          59,911
          31005
          Jun 7, 2010
          Georgia
          Local Time:
          12:26 PM
          Seam sealer!
          • Agree Agree x 1
          • cudascott
            1,591
            446
            Jan 11, 2012
            TN
            Local Time:
            12:26 PM
            My bad guess I should have read a bit better
          • RustyRatRod
            59,911
            31005
            Jun 7, 2010
            Georgia
            Local Time:
            12:26 PM
            You made a mistake not! You were right on target for a butt weld. I said butt.
            • Like Like x 1
            • Thanks! Thanks! x 1
            • plymouth67
              plymouth67 It be a lot cooler if you did...
              1,096
              1218
              Sep 13, 2010
              illinios
              Local Time:
              11:26 AM
              If your going with a flange style repair then use metal bond epoxy instead of welding it. No warping, no grinding the welds down, very little filler needed after, and the epoxy seals the back side of the repair from ever rusting. Oh yeah it's also about 3 times faster to do...
              • Like Like x 1
              • Agree Agree x 1
              • RustyRatRod
                59,911
                31005
                Jun 7, 2010
                Georgia
                Local Time:
                12:26 PM
                I've read lots of good reviews about gluing panels on. Who'dathunkit?
              • plymouth67
                1,096
                1218
                Sep 13, 2010
                illinios
                Local Time:
                11:26 AM
                It's really the same stuff they have been gluing the tops on the high top conversion vans for like 35 years....you ever seen one of those blow off...lol.
              • RustyRatRod
                59,911
                31005
                Jun 7, 2010
                Georgia
                Local Time:
                12:26 PM
                In all honesty, they could probably use silicone calk. I don't think it would ever come off by itself.
              • harrisonm
                harrisonm Well-Known Member
                2,550
                2337
                Jan 16, 2005
                Topeka, KS
                Local Time:
                5:26 PM
                Totally agree that bonding is good. However, the panels have to fit really well. The adhesive does a great job but gaps found in a poor fit will greatly reduce the seam's strength.
              • bob7four
                99
                10
                Feb 8, 2016
                New Jersey
                Local Time:
                12:26 PM
                To Dartnut... yes panel is laid in the flanged existing metal. Picture is attached.
                • Like Like x 1
                • Dartnut
                  10,720
                  3018
                  Apr 19, 2007
                  Southern Alberta
                  Local Time:
                  10:26 AM
                  Looks good to me.
                  The use of clecos is a great idea!
                • sireland67
                  sireland67 Well-Known Member
                  8,942
                  3097
                  Oct 27, 2010
                  WV
                  Local Time:
                  12:26 PM
                  It looks like on the right side, the patch panel is actually too high, lay a straight edge, as long as the patch panel is slightly lower you are good to go.
                  And I would also would glue the panel on.
                • Tooljunkie
                  Tooljunkie King of cobble/master of the broken bolt FABO Gold Member
                  14,153
                  13120
                  Jul 22, 2017
                  Manitoba
                  Local Time:
                  11:26 AM
                  Guess it depends on the climate. have seen bonded panels rust right off. No experience with only summer driven cars.
                • bob7four
                  99
                  10
                  Feb 8, 2016
                  New Jersey
                  Local Time:
                  12:26 PM
                  Glue and weld? Will the heat from welding affect the glue or is there something that will hold up? The glue would seal that seem nicely.
                • sireland67
                  8,942
                  3097
                  Oct 27, 2010
                  WV
                  Local Time:
                  12:26 PM
                  They bond a lot of panels OEM
                  You have to stay away from the glue like 2” if welding near it.
                • adriver
                  adriver Blazing Apostle
                  7,563
                  4215
                  Jun 1, 2007
                  Where the red fern grows
                  Local Time:
                  12:26 PM
                  Lord Fusor "weld through" adhesive.
                  Several types. Designed for spot welding if necessary for new car repairs.
                  Thing is I contacted them re that very thing.
                  As expected, it would take more than a hobbyist spot welder to accomplish it correctly.
                  Bottom line, just use the adhesive sans welding if that is what you want to do.
                • sireland67
                  8,942
                  3097
                  Oct 27, 2010
                  WV
                  Local Time:
                  12:26 PM
                  Good to know, I used 3M OEM stuff it said stay away 2”
                • plymouth67
                  1,096
                  1218
                  Sep 13, 2010
                  illinios
                  Local Time:
                  11:26 AM
                  I use Lord Fusor products, just put in a wheel arch patch in my son's truck over the weekend with it.
