Bypass hose and fitting dilemma
Small Block Mopar Engine
  1. prorac1
    prorac1 Well-Known Member
    1,147
    804
    Sep 29, 2012
    Martin, Mi
    Local Time:
    4:14 PM
    1983 318 with an early 273 timing cover and drivers side water pump. Holley aluminum intake.
    Water pump and intake has no fittings. Just 3/4 pipe thread holes.
    Here's the dilemma. I picked up both bypass hoses. Early and late. Than I picked up some 3/4npt x 3/4" barb fittings.
    Than I discover that the late model hose is 1" ID (way to big), but the early hose is still 13/16". Lol.
    3/4 npt x 3/4" barb is the biggest brass fitting I've been able to find.
    The 3/4 barb fits the 13/16" hose "OK", and it might snug up with the hose clamps. But it dosent slip onto the barb as snug as I would like.
    What's every one running and where do you get your fittings? Menards isn't getting it done for me this time. Lol.
    Also need to source the 3/8 npt x 5/8 heater hose fittings as well.
    Thanks. Eric
  2. Krooser
    Krooser Reform School Graduate
    831
    454
    Jul 19, 2015
    Land of Cheese
    Local Time:
    3:14 PM
    Find some used ones...
  3. sireland67
    sireland67 Well-Known Member
    7,566
    1537
    Oct 27, 2010
    WV
    Local Time:
    4:14 PM
    McMaster-Carr
    • Like Like x 1
    • 67Dart273
      67Dart273 Well-Known Member
      38,641
      6247
      Oct 14, 2010
      Idaho
      Local Time:
      1:14 PM
      Go down to HD or Lowes and buy a 3/4" nipple x" long, say, 6. If you don't have some way to clamp it without thread damage, buy a coupling "or something" so you can clamp it in the vise. Go home, saw the thing off so you have threads and an appropriate length of nipple, and install your hose.
      If you are "inventive" you can pliers tighting the thing "way out" at the end so the hose goes over any scarring and the clamp is up near the threads, IE it will seal
      • Like Like x 1
      • jazak5
        jazak5 Well-Known Member
        466
        126
        Aug 6, 2015
        NY
        Local Time:
        4:14 PM
        • Like Like x 1
        • prorac1
          1,147
          804
          Sep 29, 2012
          Martin, Mi
          Local Time:
          4:14 PM
          I'm assuming this is because the 3/4npt nipple has the same tube diameter as the 1" hose, and your not dealing with barb size?
        • prorac1
          1,147
          804
          Sep 29, 2012
          Martin, Mi
          Local Time:
          4:14 PM
        • 67Dart273
          38,641
          6247
          Oct 14, 2010
          Idaho
          Local Time:
          1:14 PM
          Yes 3/4 is pretty close to 1" OD
          On a side note, 1/8 is close enough to 3/8OD that you can use it sometimes for fuel connections, and 3/8 is close to 5/8 for heater hose use.
          • Like Like x 1
          • lemondana
            lemondana BlackDart
            242
            67
            Dec 7, 2007
            Southeast NE
            Local Time:
            3:14 PM
            There is a place called FittingsandAdapters.com that has all of those fittings you can't find elsewhere. The one for the Holley intake is part no. BHB-12-12, 3/4 hose id. and 3/4 male pipe thread. I'm sure they have the water pump fitting also. You have to look real hard on their website so you don't overlook them.
            • Like Like x 2
            • krazykuda
              krazykuda FABO Gold Member FABO Gold Member
              46,014
              11134
              Aug 20, 2007
              Orland Park, IL
              Local Time:
              3:14 PM
              • Like Like x 4
              • 65wgn440
                65wgn440 Well-Known Member
                251
                107
                Aug 16, 2016
                Toledo, ohio
                Local Time:
                5:14 PM
                You can also get a kit from Summit or Mopar Performance that includes the hose, clamps, and one 3/4 npt x 1" nipple. If your water pump is 3/4 npt also, you can get another fitting separately. Just went through this, also.
                • Like Like x 1
                • YY1
                  YY1 Well-Known Member
                  5,450
                  1216
                  Oct 11, 2011
                  FL
                  Local Time:
                  4:14 PM
                  Go to the u-pull with a pipe wrench and a strap wrench.
                  I also have, believe it or not, a gate hinge that works in the slots of the nipple.
                  They might not even charge you.
                  I always harvest the ones from my used pumps before they either go back as cores or go to scrap.
                • prorac1
                  1,147
                  804
                  Sep 29, 2012
                  Martin, Mi
                  Local Time:
                  4:14 PM
                  Went to granger this morning on my way to work and ordered all 4 fittings. They should be in tomorrow. Thank you again for all the help everyone. Eric
                  • Like Like x 1
                  • 67Dart273
                    38,641
                    6247
                    Oct 14, 2010
                    Idaho
                    Local Time:
                    1:14 PM
                    By the way use teflon tape or sealant to keep the threads from sticking and RESIST the urge to tighten them. Just snug them........REMEMBER---pipe threads are tapered and you can easily break a casting, 'specially 'luminum, and even iron
                    • Like Like x 1
                    • 65ChargerDart
                      65ChargerDart 65ChargerDart FABO Gold Member
                      282
                      94
                      Jun 25, 2005
                      Fortson, GA
                      Local Time:
                      4:14 PM
                    • 65ChargerDart
                      282
                      94
                      Jun 25, 2005
                      Fortson, GA
                      Local Time:
                      4:14 PM
                      The part has changed and the hose end is now barbed.
