Bypass hose tube issue?
gm1236
Massachusetts
69 340 GTS, intake bypass hose nipple is much small then the hose nipple on the water pump. This Is a cast iron manifold and steel water pump, could be a Milodon, not sure. Is there a magic hose to fix this? Water pump was recently replace, not sure what happen to the old one. This wasn’t an issue with that one.
Change the fitting in one or the other at the manifold or water pump.
