[WANTED] Cable shifted 904
Wonderful. I have a 1967 904 out of a 273 Barracuda that was working when pulled if you want to trade. I am out of town till 4/11, but can pick it up after that. Will PM you with my information.
This one would need rebuilt I'm sure. Don't need your trans , sorry But this one is cheap. $25 if you come get it !
It has the ball & trunion output..Not a slip yoke. Not home at the moment. But I can send pics later.
Just a FYI. 1965 trans is a one year only beast. A 1964 trans can be used but the valve bodies are different. It all depends on the type shifter. Push button shifter had a valve body with 5 detent positions. Floor shifter or column shifter had a valve body with 6 detent positions.
Ok, I can pick it up this weekend. Sunday afternoon/evening works, but if Sat is what your open for, I will make it happen Sat.
Do you know if this is a 5 or 6 detent valve body?
I will take it. I can leave here at 9, probably be there before 11 AM if that works. Just let me know.
