Calling On The Cooling Gods
Discussion in 'Heating / Cooling / AC' started by superchargeddrt, Apr 16, 2018.
  1. superchargeddrt
    superchargeddrt FABO Gold Member FABO Gold Member
    1,810
    450
    Aug 24, 2009
    Pittsburgh, Pa.
    Local Time:
    11:35 AM
    Okay,
    So I have my new 418 stroker in the engine compartment and my Champion aluminum radiator installed. The problem I have is that in order to use a mechanical fan and for the shroud to be centered on the radiator core the radiator has to be biased to the passenger side (looks STUPID) So I want to go electric a but I have limited space. I only have 3 3/8" from the core to the bolts on the water pump pulley. The radiator dimensions are: Core 21" x 17 5/8" Radiator core + tanks 26" x 18 5/8. I am betting that I will have to mortgage the house to find a radiator/shroud assembly to fit this. Any help would be appreciated. Thanks Guys
  2. dukeboy_318
    dukeboy_318 Our Lives, Our Fortunes and Our Sacred Honor. FABO Gold Member
    27,495
    8246
    Jan 19, 2007
    la la la la
    Local Time:
    11:35 AM
    there's some thin fans out there or you could run pusher fans. Champion was selling a shroud and fan kit for a decent price, if not, rob some from a junkyard and make a custom shroud
  3. roccodart440
    roccodart440 Well-Known Member
    4,678
    3682
    Apr 19, 2010
    Local Time:
    11:35 AM
    When I ran a smaller radiator I ran 2 fans. One puller and one pusher .
  4. Darticon
    Darticon FABO Gold Member FABO Gold Member
    113
    34
    Aug 29, 2014
    Missoula, MT
    Local Time:
    9:35 AM
    There are a few companies that make shroud/fan combos specifically for the Champion radiators. For the EC374 I have, I bought these two kits off of eBay:
    ALUMINUM RADIATOR FAN SHROUD FITS CHAMPION CC374 MC374 EC374 AE374 W/ 12" FANS
    Dual Electric Cooling Fan Wiring Install Kit 185/165 Thermostat 50 Amp Relay
    The shroud itself holds the fans off the radiator about an inch. Then the fans at their center are about 2.5" thick. The fans sit side by side and are only about 1.5" tall near their edges so toward the center of the shroud/fan combo you should have good clearance.
  5. yellow rose
    yellow rose Doctor of Thinkology.
    15,153
    11746
    Jun 19, 2015
    Living on the razors edge
    Local Time:
    8:35 AM
    I'd the fan is close enough to the radiator you don't need a shroud. I don't run a shroud.
  6. superchargeddrt
    1,810
    450
    Aug 24, 2009
    Pittsburgh, Pa.
    Local Time:
    11:35 AM
    Well I am gonna give that a try before I lay out mondo cash.
  7. autoxcuda
    autoxcuda Well-Known Member
    6,046
    413
    Apr 6, 2007
    View My Photos
    Local Time:
    8:35 AM
    Are you running the 70-up aluminum radiator or the 69-down cast iron?
    I run the aluminum water pump and 4 core champion. Need that new Hayden shorty vintage fan clutch.
    Then make a shroud...
    Building a Custom Fan Shroud: Pic by Pic
    • Thanks! Thanks! x 1
    • famous bob
      famous bob mopar misfit
      9,937
      2192
      Aug 14, 2011
      okla
      Local Time:
      10:35 AM
      I bought an alum. shroud from summit and reworked the hell out of it, just takes a little imagination.
      • Like Like x 1
      • Agree Agree x 1
      • subcom
        subcom Well-Known Member
        1,122
        263
        Sep 17, 2010
        South Florida
        View My Photos
        Local Time:
        11:35 AM
      • superchargeddrt
        1,810
        450
        Aug 24, 2009
        Pittsburgh, Pa.
        Local Time:
        11:35 AM
        NICE! See I knew someone has done this before. Thank you very much. I will order one ASAP and thanks to everyone else who replied to this thread, I greatly appreciate it .
        • Like Like x 1
        • rednesss
          rednesss FABO Gold Member FABO Gold Member
          1,382
          96
          Mar 4, 2006
          Eugene, OR
          Local Time:
          8:35 AM
          I also run an OEM double, 2 speed fan. It's from a 2000-04 Ford Focus. It does take some cutting and fitting to remove some of the plastic on the sides, but it's a hurricane when on high speed, so I think it's worth it.
        • superchargeddrt
          1,810
          450
          Aug 24, 2009
          Pittsburgh, Pa.
          Local Time:
          11:35 AM
        • subcom
          1,122
          263
          Sep 17, 2010
          South Florida
          View My Photos
          Local Time:
          11:35 AM
