1. j par
    j par Well-hung Member
    19,268
    9420
    Jul 2, 2014
    Portland Oregon
    Local Time:
    9:16 AM
    I'm not sure which one of these Cam and lifters I want to put in? 73 D100, granny 4-speed, 355 gear, 1 tire fire, 235/75/15.. 318 with 150 lbs cracking pressure, 2 barrel, single stock exhaust...
    I'm just stabbing the cam in and lifters with a new timing chain and gears..
    New oil pump and reseal the motor..
    It will likely be one of these two cheap cams from Summit but I'm just back and forth on which one?.. I will be adding power brakes. I'm probably just a direct line from the intake manifold..
    Any suggestions are welcome thank you..
    • Disagree Disagree x 1
    • toolmanmike
      toolmanmike FABO Staff Staff Member FABO Gold Member
      44,827
      28563
      Jan 18, 2006
      Iowa
      Local Time:
      11:16 AM
      6900 you need all the bottom end you can get in a truck.
      • Agree Agree x 5
      • Like Like x 2
      • j par
        19,268
        9420
        Jul 2, 2014
        Portland Oregon
        Local Time:
        9:16 AM
        That was kind of my first choice..
        • Agree Agree x 2
        • Like Like x 1
        • rumblefish360
          rumblefish360 So close, yet so far away
          36,683
          8514
          Jun 21, 2005
          New York, on a Island
          Local Time:
          12:16 PM
          .750 roller!
          :rofl:
          • Like Like x 2
          • Thanks! Thanks! x 1
          • 318willrun
            318willrun have a great day
            12,034
            11704
            Sep 13, 2013
            I'm here
            Local Time:
            11:16 AM
            If it's not going to see above 3500 rpms, I'd leave the stock cam in it. Put a new timing set in it, work with the curve in the distributor. JMO
            • Agree Agree x 2
            • Like Like x 1
            • j par
              19,268
              9420
              Jul 2, 2014
              Portland Oregon
              Local Time:
              9:16 AM
              No I don't see it going to thirty-five hundred RPMs for any reason.
              I was more looking to breathe a little life into it make it sound good and look good.. give it a little Rumble make it sound like it's got something going on maybe.. what it looks good sounds good and runs good it seems to sell a little easier...?..
              Trust me I would rather not spend the money.
            • Garrett Ellison
              Garrett Ellison Amateur driver on public roadway, do not imitate.. FABO Gold Member
              1,987
              1444
              Jan 1, 2018
              Southwest VA
              Local Time:
              12:16 PM
              If your keeping the single exhaust, I'd be looking toward this direction, especially if your not planning on changing valve springs, etc. Melling M-Select Class 1 Camshafts 23103 If my present situation were better and I were closer, I'd already be there trying to buy it from you. I still miss my '73 D100. Same options but mine had a \6. Got any pics?
              • j par
                19,268
                9420
                Jul 2, 2014
                Portland Oregon
                Local Time:
                9:16 AM
                Plenty of pictures on grandson of seed truck...
                • Like Like x 1
                • RustyRatRod
                  RustyRatRod 30 Degrees Outta Whack FABO Gold Member
                  57,339
                  26787
                  Jun 7, 2010
                  Georgia
                  Local Time:
                  12:16 PM
                  Get a custom Jones cam. Pay them 350 dollars for a custom cam goin in a old POS truck, cause that's the best thing according to forum gurus.
                  You want a good cam for that truck, seriously? Put the Crane magic cam in it. It'll cost a little more than the Summit cam but man that'll set it on fire. All these self proclaimed forum gurus will scoff at the 114 LSA but I have real world experience with it. It flat WORKS.
                  Crane Hydraulic Flat Tappet Camshafts 693801
                  • Agree Agree x 1
                  • Garrett Ellison
                    1,987
                    1444
                    Jan 1, 2018
                    Southwest VA
                    Local Time:
                    12:16 PM
                    Thanks, Rusty! May be wanting to try that one myself. What ICL do you like to put that on?
                  • RustyRatRod
                    57,339
                    26787
                    Jun 7, 2010
                    Georgia
                    Local Time:
                    12:16 PM
                    Totally dependent on what the static compression is. 110 at the "least" and probably somewhere down around 106 at the "most". It just depends.
                    • j par
                      19,268
                      9420
                      Jul 2, 2014
                      Portland Oregon
                      Local Time:
                      9:16 AM
                      Remember I'm just trying to give it just the slightest bit of life and Rumble..
                      This is going in an old granny 4-speed truck..
                      A 494 lift with stock Springs.. I think by the time I do lifters break in oil and all that crap I'll be well over $200.. I'm trying to keep costs low because I'm just fixing it up to sell.. I would think this would be a more viable option if I was sticking this motor in my Duster?...
                    • RustyRatRod
                      57,339
                      26787
                      Jun 7, 2010
                      Georgia
                      Local Time:
                      12:16 PM
                      If you refuse to replace the springs, then leave the stock cam in it. ANY new camshaft should get new springs.
                      • Like Like x 2
                      • Agree Agree x 2
                      • mbaird
                        mbaird mbaird FABO Gold Member
                        5,391
                        2422
                        Dec 10, 2005
                        boise, Id
                        Local Time:
                        10:16 AM
                        3.55s and 27” tall tires ? I cant see how you won’t see over 3500 rpms unless its a farm truck. I would give it a few more RPMs.
                        • Like Like x 1
                        • RustyRatRod
                          57,339
                          26787
                          Jun 7, 2010
                          Georgia
                          Local Time:
                          12:16 PM
                          I RARELY rev my truck to 3K. It has 3.73 gears and no OD with 238/85 16s.....however tall they are.
                          • Agree Agree x 2
                          • j par
                            19,268
                            9420
                            Jul 2, 2014
                            Portland Oregon
                            Local Time:
                            9:16 AM
                            I know my Duster has 354's with 27 3/4 in. tires and I'm at 3k at 65 mph...
                          • fishmens67
                            fishmens67 Well-Known Member
                            6,577
                            3598
                            Nov 10, 2012
                            idaho
                            Local Time:
                            11:16 AM
                            I have the cam in a 73 W200 360/auto with factory 4.10 's. sweet cam
                            Pull the trigger, no need to change springs for the intended purpose of a truck.
                            • Like Like x 2
                            • Agree Agree x 1
                            • fishmens67
                              6,577
                              3598
                              Nov 10, 2012
                              idaho
                              Local Time:
                              11:16 AM
                              FWIW when I bought the K6900 Crane was grinding Summit cams. Don't know about now, it's been a few years.
                              • Like Like x 1
                              • j par
                                19,268
                                9420
                                Jul 2, 2014
                                Portland Oregon
                                Local Time:
                                9:16 AM
                                Should get..
                                I'm already not parting/scrapping the truck.. I'm trying to give it just a little bump and not wanting to go down a rabbit hole.. the $122.99 is a stretch..
                                If this was 30 years ago I'd go to the wrecking yards and pull a cam and lifters out of a la 360..
                                If this was something I was keeping it would get the completely different treatment..
                                • Like Like x 1
                                • RustyRatRod
                                  57,339
                                  26787
                                  Jun 7, 2010
                                  Georgia
                                  Local Time:
                                  12:16 PM
                                  I'm not saying build the whole engine. Just not to cut corners on certain things. DO it like you want to. Good luck with it.
                                  • Like Like x 2
                                  • j par
                                    19,268
                                    9420
                                    Jul 2, 2014
                                    Portland Oregon
                                    Local Time:
                                    9:16 AM
                                    That's exactly what I was thinking..
                                    If I was going to Rev this up or use it for some kind performance or something and keep it again that would be a different story...
                                    • Like Like x 1
                                    • j par
                                      19,268
                                      9420
                                      Jul 2, 2014
                                      Portland Oregon
                                      Local Time:
                                      9:16 AM
                                      It's just another thing that's starting down the rabbit hole...
                                      Of course I split the transmission from the motor and it needs a new clutch..
                                      I pull the motor and it needs new motor mounts.. of course I've already bought a timing chain and gears because we know that's going to need it.. I just sent for the new floor boards.. I just sent for the gasket kit so the motor can be resealed..
                                      I'm giving the truck my power steering box and pump that I have from another truck as well as power brakes.. I have a steering wheel from the last truck that's not cracked.. I have a rear view mirror you can actually see out of... it's going to need all new U joints and carrier bearing..
                                      New gear oil in the rear end and the Transmissions.. it's going to need new door seals and carpet to cover the floor boards that I put in..
                                      I need to K.I.S.S....
                                      • Like Like x 1
                                      • j par
                                        19,268
                                        9420
                                        Jul 2, 2014
                                        Portland Oregon
                                        Local Time:
                                        9:16 AM
                                        I didn't say your suggestion wasn't good I just don't think it's necessary for this particular application...
                                      • Bodyperson
                                        Bodyperson Keep yer nose to the wind
                                        3,644
                                        4373
                                        Nov 26, 2015
                                        NW MONTANA
                                        Local Time:
                                        10:16 AM
                                        Should have stopped after you dug the tampons out of the heater box. LOL
                                      • RustyRatRod
                                        57,339
                                        26787
                                        Jun 7, 2010
                                        Georgia
                                        Local Time:
                                        12:16 PM
                                        New springs are necessary for any new camshaft, regardless of application. But it's your truck and if you want to cut corners that shouldn't be cut, then have at it. I don't give a crap what your opinion is, it's wrong here. If that's what you want, just leave the engine alone. That's what I'd do. I would leave the engine as is and concentrate on making the body nice.
                                        • Agree Agree x 2
                                        • Like Like x 1
