1. Musk
    Musk New Member
    4
    4
    Sep 21, 2021
    Minnesota
    Local Time:
    3:39 PM
    This is my first post. I don't have an a body, but I have a 360 that I need some help with on choosing the correct cam for my use.
    What I have are 9.5 to 1 pistons, a set of speedmaster aluminum heads. Rotating assembly has been machined and balanced. Stock rods that were polished and shot pinned. 2400 stall speed converter with 904 trans. Transmission was rebuilt with race bands and clutches. Would like to put a manual valve body sometime. I have and 8.75 rear end with 2.94 gears, but that may change. 26.1-in tires. Car should weigh in at around 2500 to 2600 lb. This will be a weekend cruiser, cruising from town to town so driveability is of some importance. Gas mileage is of some importance. Operating range maybe off idle to 5,500 RPM. Forgot to mention I have an Edelbrock performer intake that will be port matched to the heads. There are no headers that I know of made for my car. So headers are out. I will either have to go with some 340 exhaust manifolds or shorty headers with 2 1/2 inch stainless exhaust. I want this thing to be able to lay you back in the seat good and hard. I would like some suggestions on a cam that would suit me. Does anyone else have any combos similar to mine... Let me know... Thanks
  2. Rmoore
    Rmoore Well-Known Member
    622
    477
    Nov 14, 2018
    Gun Barrel City, Texas
    Local Time:
    3:39 PM
    What car
  3. 64mopar
    64mopar Well-Known Member
    254
    289
    Apr 14, 2019
    PittsBurgh
    Local Time:
    4:39 PM
    With your compression and gears,putting you "back in your seat "will be hard.
    Get a towing or torque cam.
    • Disagree Disagree x 2
    • Like Like x 1
    • toolmanmike
      toolmanmike Moderator Staff Member FABO Gold Member
      61,310
      49832
      Jan 18, 2006
      Iowa
      Local Time:
      3:39 PM
    • Musk
      Musk New Member
      4
      4
      Sep 21, 2021
      Minnesota
      Local Time:
      3:39 PM
      Plymouth Arrow
      • Like Like x 2
      • Musk
        Musk New Member
        4
        4
        Sep 21, 2021
        Minnesota
        Local Time:
        3:39 PM
        I would go as low as 3.23 for gears.
        • Like Like x 1
        • rumblefish360
          rumblefish360 Getting closer FABO Gold Member
          41,849
          13455
          Jun 21, 2005
          New York, on a Island
          Local Time:
          4:39 PM
          Garbage cam. (Sorry Mike)
          What car is this in? Is it a B body?
          2400 stall, 26 inch tires, car weight of 2600lbs., speedmaster heads and a Edelbrock Performer intake, 294 gears, weekend cruiser.
          IMO, you need more gear. Step up to 3.55’s.
          In order to “Put you back in your seat”, you’ll need a good bit more gear and a really good higher stall converter. Something like 4.30 gears & at least a 3500 converter.
          Also, the heads are not being used very well with low lift cams. I’m isn’t easy finding high lift cams with short durations that operate to only 5500 rpm.
          For you currently, I suggest a cam of no more duration @.050 than 224.
          These are an example;
          Xtreme Energy 218/224 Hydraulic Flat Cam for Chrysler 273-360
          Hydraulic Flat Tappet Street Force 3 Camshaft; 1964 - 2003 Chrysler 273, 340, 360 1600 to 5800 Howards Cams 712121-12 | Howards Cams
          • Like Like x 1
          • Agree Agree x 1
          • rumblefish360
            41,849
            13455
            Jun 21, 2005
            Local Time:
            4:39 PM
            I knew a guy running 9’s in an arrow through exhaust manifolds.
            That was a looooooooog time ago.
            • Like Like x 2
            • Johnny Dart
              Johnny Dart Well-Known Member
              8,407
              3129
              Nov 30, 2006
              So Cal
              Local Time:
              1:39 PM
              Rumble suggested the XE262H, I was going to suggest the XE268H. I have the 268 in my mild 360, with 340 manifolds, 355 gear, and it works nicely.
              Another I would suggest taking a look at would would be the Lunati voodoo line. Something like the 256/262. They call it the "701" cam. I'm building a new 360 now, and probably going with the voodoo 701 or 702 cam.
              On another note: Alot of these camshafts don't even look like they're available at the moment.
            • toolmanmike
              61,310
              49832
              Jan 18, 2006
              Iowa
              Local Time:
              3:39 PM
              Ya, I don't own one. Didn't know they were available until here lately. I don't hear much good about Comp any more either.
            • dartfreak75
              dartfreak75 Restore it, Dont part it! FABO Gold Member
              10,752
              8346
              Aug 10, 2011
              Virginia
              Local Time:
              4:39 PM
              Luniti voodoo. The 703 maybe a little large for 9:1 compression id go with either the 701 or 702. Im running the 702 with basically stock heads and 10:1 and its strong!
              • Agree Agree x 1
              • 33IMP
                33IMP Well-Known Member
                1,633
                1718
                Jul 3, 2020
                Taxifornia, soon 2b arizona
                Local Time:
                1:39 PM
                Third vote for a lunati voodoo. Pick the cam to match your rear end gear. 2.9x gear, smallest cam. 3.55, mid size cam . 4.10/4.30, big boy cam.
                • Like Like x 1
                • j par
                  j par Well-hung Member
                  28,985
                  16219
                  Jul 2, 2014
                  Portland Oregon
                  Local Time:
                  1:39 PM
                  A NEWBIE CAM THREAD! FIGHT FIGHT FIGHT FIGHT! LOL...
                  You don't know cams from cornstarch! That's the wrong cam I agree with that cam too much duration too much lobe lift not enough separation...
                  Where am I I'm old what happened...
                  • Like Like x 2
                  • Musk
                    Musk New Member
                    4
                    4
                    Sep 21, 2021
                    Minnesota
                    Local Time:
                    3:39 PM
                    Lol
                    • Thanks! Thanks! x 1
                    • rumblefish360
                      41,849
                      13455
                      Jun 21, 2005
                      Local Time:
                      4:39 PM
                      Comp has grinds that would fit. Many companies do.
                      I’d have one made on a 106 to bolster low end torque. Add lift and 1.6 rockers to get that head flowing some air.
                      • Agree Agree x 1
                      • RustyRatRod
                        RustyRatRod I was born on a Monday. Not last Monday. FABO Gold Member
                        77,844
                        55310
                        Jun 7, 2010
                        Georgia
                        Local Time:
                        4:39 PM
                        I like the 268 cams for this. IMO the Lunati version of the 268 is a bit better than Comp's. Splittin hairs, but that's my opinion.
                        • Like Like x 2
                        • Agree Agree x 2
                        • roccodart440
                          roccodart440 Well-Known Member
                          5,865
                          4813
                          Apr 19, 2010
                          Local Time:
                          4:39 PM
                          You'll want something cut on a smaller LSA to increase cylinder pressure. I couldn't find anything that really made me happy off the shelf for your build. The closest I found was comp cams 20-616-5 but it had a little more duration than i'd preffer.
                          242@.050 // .540 lift // 106LSA
                          • Like Like x 1
                          • Agree Agree x 1
                          • PRH
                            PRH Well-Known Member
                            3,424
                            5048
                            Dec 14, 2018
                            So. Burlington, Vt
                            Local Time:
                            4:39 PM
                            Comp 268H
                            Comp XE262
                            Lunati Voodoo 702
                            • Agree Agree x 3
                            • toolmanmike
                              61,310
                              49832
                              Jan 18, 2006
                              Iowa
                              Local Time:
                              3:39 PM
                              Yep, that's too big in the wrong places. Like the cams from decades ago, all duration and no lift. This one is closer to the 340-4 barrel specs. Who grinds these cams? I thought it was Crane but they got bought out from what I understand.
                              Summit Racing SUM-K6901 Summit Racing® Classic Cam and Lifter Kits | Summit Racing It looks like the OP could have a fun combination with a little more gear. It wouldn't take much of a 360 to make it scat. Gas mileage? You won't get much.
                              • Agree Agree x 1
                              • Krooser
                                Krooser Reform School Graduate
                                3,275
                                2811
                                Jul 19, 2015
                                Central Wisconsin
                                Local Time:
                                3:39 PM
                                Ask if the cam you like is made for the Mopar .904 lifter diameter. Most are not. They are Chevy grinds on an .842 core.
                                Howards can grind a Mopar grind on a Mopar 904 core. Your OEM cam was on a .904 core....why go backwards? A 904 grind gives you nearly roller cam performance according to Mike @ Jones Cams.
                                Howards also grinds Mopar cams for another Mopar shop.
                                The biggest thing you have to face is supply...there is a six month backorder on many cams right now. I was quoted 6-8 months on a new crank. Good luck.
                                • Agree Agree x 2
                                • rumblefish360
                                  41,849
                                  13455
                                  Jun 21, 2005
                                  Local Time:
                                  4:39 PM
                                • roccodart440
                                  5,865
                                  4813
                                  Apr 19, 2010
                                  Local Time:
                                  4:39 PM
                                  In the end it's your build, but I see a few things that to me are undesirable about that cam. The first is the LSA. You have 9.5:1 compression, I'd be looking at something less than 110 degrees. In fact i'd be considering 106 or less. That's coming from a guy who nearly always favors wide LSA's.
                                  The second thing is the lift is just making par on this one. I'd want to see .525 minimum, preffer .550+
                                  Last, I always prefer solid lifters and would seriously consider a roller cam if you can afford it. When the cam wipes out, you'll wish you went roller.
                                  • Agree Agree x 1
                                  • rumblefish360
                                    41,849
                                    13455
                                    Jun 21, 2005
                                    Local Time:
                                    4:39 PM
                                    @roccodart440 Yep! Even though I did list that cam above, earlier I did say I’d have a cam ground on a 106 to bolster torque. I think we both see the plus in that move.
                                    With 1.6 rockers, lift comes in at .547/.560.
                                    Gotta get them heads working!
                                    • Agree Agree x 1
                                    • rumblefish360
                                      41,849
                                      13455
                                      Jun 21, 2005
                                      Local Time:
                                      4:39 PM
                                      There flow numbers are this or something like this;
                                      Flow Data @ 28″ water
                                      lift 100 200 300 400 500 600
                                      Int 71 133 191 236 251 254
                                      Ext 66 111 145 173 185 193
                                      Flow starts to pick up nicely after .400.
                                      • Like Like x 1
                                      • mopowers
                                        mopowers Well-Known Member
                                        5,917
                                        3081
                                        Feb 15, 2006
                                        West Sacramento, CA
                                        Local Time:
                                        1:39 PM
                                        Do we even know what the OP's actual SCR is? He simply stated he has "9.5 to 1 pistons." Has the compression ratio been verified with actual measurements??
                                        • Like Like x 1
                                        • Agree Agree x 1
