Cam eccentric on 340
Small Block Mopar Engine
  1. JG1966
    JG1966 Well-Known Member
    68
    29
    Feb 15, 2018
    Pittsburgh
    Local Time:
    10:43 PM
    Should the cam eccentric on a 340 wobble, rattle and be loose when I prod at it with a screwdriver through fuel pump opening? It didn't seem right to me but the guy who refreshed motor over the winter says it's perfectly normal and all cam eccentrics are loose and move side to side. Is that right?
  2. JBurch
    JBurch FABO Gold Member FABO Gold Member
    1,939
    1097
    Oct 17, 2009
    Owego, NY
    Local Time:
    10:43 PM
    NO, it should NOT be loose, or rattle, that would mean that your timing chain sprocket is loose and rattly. Get it fixed and send him the bill; charge him double for being stupid!
    • Agree Agree x 3
    • Like Like x 1
    • Thanks! Thanks! x 1
    • MoparLeo
      MoparLeo NRA BENEFACTOR LEVEL LIFE MEMBER FABO Gold Member
      872
      618
      Feb 10, 2016
      Moreno Valley, Cal. So. Cal.
      Local Time:
      7:43 PM
      TOTAL BS !! It should probably be replaced. It can be replaced on the car. If the key way on the eccentric is a loose fit on the Woodruff key it needs to be replaced. Also the woodruff key should be replaced. The factory torque spec for eccentric bolt is 35 ft. lbs. I would also use Blue Lock-Tite. Had one come loose many, many years ago. It left me in the middle of no where. Was inexpensive to fix but very inconvenient and a big tow bill.
      • Agree Agree x 1
      • JG1966
        68
        29
        Feb 15, 2018
        Pittsburgh
        Local Time:
        10:43 PM
        They put the washer on upside down!! I'm amazed it ran as long as it did.
      • 65Val
        65Val Average Length Member
        5,297
        1248
        Oct 14, 2005
        Victoria, BC, Canada, EH!
        Local Time:
        7:43 PM
        Your "refresh guy" should only be allowed to refresh Chevy's.
        • Agree Agree x 6
        • Like Like x 2
        • JG1966
          68
          29
          Feb 15, 2018
          Pittsburgh
          Local Time:
          10:43 PM
          Yeah, the ridiculous thing is they are one of the best shops around and build race motors for the local drag strip much, much nicer than my little 340. I sent him a photo and asked if he can do something to make me feel a little better about this.
        • Max1196
          Max1196 Well-Known Member
          988
          720
          May 12, 2016
          Swift Current SK
          Local Time:
          8:43 PM
          How much more did he "refresh"? Rods, Mains, Rings. Have a qualified trustworthy person take a look and give you an opinion.
          • Agree Agree x 2
          • mbaird
            mbaird mbaird
            7,382
            4139
            Dec 10, 2005
            boise, Id
            Local Time:
            8:43 PM
            Anyone can make a mistake. What would scare me is the BS line !
            Trust ?
            • Agree Agree x 4
            • RustyRatRod
              RustyRatRod I was born on a Monday. Not last Monday. FABO Gold Member
              77,249
              54341
              Jun 7, 2010
              Georgia
              Local Time:
              10:43 PM
              Not like that. That's what shop manuals are for. After I was hurt on the job several years ago, I had to contract with a local shop to build a 360 for a truck I had. ....among other things, they put the rocker shafts on backwards and several rockers on backwards. They had an entire machine shop library 4 shelving units wide in the corner of the shop. Could have looked up that information easily.
              If you are going to be in the business, it's in for a penny in for a pound if you are taking peoples' hard earned money. Absolutely no excuse for mistakes like that, AT ALL.
              • Agree Agree x 1
              • yellow rose
                yellow rose Overnight Sensation FABO Gold Member
                28,619
                25204
                Jun 19, 2015
                Central Washington
                Local Time:
                7:43 PM
                I agree. Even without the books and manuals there is NO REASON for that. Why would Chrysler go to all the trouble of making a washer like that and then use it upside down? They could have used a flat washer.
                That's dumb.
                • Like Like x 1
                • Agree Agree x 1
                • gzig5
                  gzig5 FABO Gold Member FABO Gold Member
                  1,819
                  2065
                  May 3, 2018
                  Mequon, WI
                  Local Time:
                  9:43 PM
                  The paint line on the bolt head indicates that it was torqued to some spec, right? So the bolt must be bottomed out in the hole, thus the need for the special washer?
                • justinp61
                  justinp61 Well-Known Member
                  2,124
                  1683
                  May 15, 2009
                  Local Time:
                  9:43 PM
                  JG1966 you'll be lucky if it didn't ruin the cam. Also you need to look for a new engine builder.
                  • Agree Agree x 1
                  • replicaracer43
                    replicaracer43 Grumpy Old Man
                    5,061
                    4558
                    Oct 10, 2008
                    Local Time:
                    9:43 PM
                    I'd bet a dollar to a doughnut that your "refresh guy" is a chevy guy. That's just common, everyday stupidity right there.
                    • Agree Agree x 1
                    • JBurch
                      1,939
                      1097
                      Oct 17, 2009
                      Owego, NY
                      Local Time:
                      10:43 PM
                      To read a manual, you must first know how to read, people don't read anymore, they look for pictures here on the internet, one of the many ways sh$t happens...
                      • Agree Agree x 2
                      • Bobzilla
                        Bobzilla Well-Known Member
                        1,085
                        844
                        Aug 10, 2017
                        Southeast Michigan
                        Local Time:
                        10:43 PM
                        This builder probably did a couple Pontiac engines before. They have a two piece eccentric, and the outer piece does rotate freely when properly installed and torqued down, if I remember correctly.
                        Still no excuse to avoid the manuals when working on something unfamiliar to him.
                        Hope it works out ok, JG1966.
                      • JG1966
                        68
                        29
                        Feb 15, 2018
                        Pittsburgh
                        Local Time:
                        10:43 PM
                        That is a concern of mine. I've talked to him and he's going to make it right.
                      • yellow rose
                        28,619
                        25204
                        Jun 19, 2015
                        Central Washington
                        Local Time:
                        7:43 PM
                        Good on you for letting him make it right. Doesn't change the fact he made that mistake because if he just looked at the front of the engine he would have seen why that washer was made the way it is. I suspect he was just working at his normal rhythm and just blew it off.
                        None of us is perfect. I'm glad you let him make it right.
                        BTW...how many guys work in that shop.
                      • justinp61
                        2,124
                        1683
                        May 15, 2009
                        Local Time:
                        9:43 PM
                        I'd inspect the cam before he touched it again.
                      • JG1966
                        68
                        29
                        Feb 15, 2018
                        Pittsburgh
                        Local Time:
                        10:43 PM
                        The guy was really good keeping me informed doing the refresh -- he did rings, mains, new cam -- and I know he felt terrible, like an idiot, for making that mistake. I like and trust the guy. They've been around since 1965. Probably 5-6 guys work there. I have no problem giving him another chance. That's what this country is all about, right?
                      • yellow rose
                        28,619
                        25204
                        Jun 19, 2015
                        Central Washington
                        Local Time:
                        7:43 PM
                        Is it possible he let a new guy or someone with less experience put it together? Like I said...shit happens.
                      • RustyRatRod
                        77,249
                        54341
                        Jun 7, 2010
                        Georgia
                        Local Time:
                        10:43 PM
                        Exatcly. And they will possibly get wrong information, because some of the info out there is purposely wrong just to sabotage someone for the hell of it.
                      • iScamp
                        iScamp Well-Known Member
                        221
                        130
                        Nov 1, 2012
                        North Carolina
                        Local Time:
                        10:43 PM
                        The oodles of Permatex is either a sign of insecurity or someone used to taking up Chevy machine tolerances. In my opinion, he needs to use a gasket. That's way too much and unnecessary use of RTV. I"ve seen excess chunks from situations like that end up clogging the drilled coolant passages (head to block mating). Got pictures of that. Also, seen it break loose and foul the oil pick-up.
                      • iScamp
                        221
                        130
                        Nov 1, 2012
                        North Carolina
                        Local Time:
                        10:43 PM
                        I saw on social media or Youtube a situation where a guy had a late model Ford truck that would vibrate severely above 65 mph. The dealership said there was nothing to be done about it. The Service Writer told the customer, "that model of Ford truck was not designed to go over 65 mph."
                        If I can find it again, I'll post a link.
                      • Unconventional
                        Unconventional Well-Known Member
                        15,095
                        17570
                        Apr 17, 2017
                        Santa Maria, Ca.
                        Local Time:
                        7:43 PM
                        Or plug the transmission filter and fry a transmission 300 miles after a fluid and filter change.
                      • gzig5
                        1,819
                        2065
                        May 3, 2018
                        Mequon, WI
                        Local Time:
                        9:43 PM
                        I just pulled the timing cover on my 340 to check the condition of the timing chain due to a timing issue and I found the same result. Whoever was in there last installed that washer upside down. In my case it all seems tight now, doesn't rattle. There is a mark on the inside of the timing cover from the eccentric so maybe they caught the loose bolt and tightened it up. But from the wear I see on the eccentric and the arm of the new fuel pump that has only 45 minutes or so on it, it doesn't look like the eccentric is getting a lot of oil. Need to try and look into that. Anyone know where the oil comes in from for that? There was definitely some oil that dripped out the fuel pump opening when I removed it. Maybe I'm seeing ghosts....
