AJ/FormS
68 Formua-S fastback clone 367/A833/GVod/3.55s
- Joined
- Jan 19, 2014
- Messages
- 26,611
- Reaction score
- 13,844
As to the 600, heres a scenario
Lets say you told your rebuilder that your engine was pulling 15 inches of vacuum. He might have put a PV in there rated for 13 or 12 or 11inches of vacuum, cuz thats typical;idle vacuum less 2 to 4". But lets say your idle vacuum is actually closer to 12 inches which is still high for a 230*cam, but your vacuum gauge is calibrated wrong.
Now in neutral, your PV is always on the borderline of opening.Then any slight change in engine vacuum will drive the PV into opening. Putting it into gear could easily cause the PV to flood the engine to a stall.
Now I'm not saying your gauge is lying to you, just that there is no way my 230* cam will pull 15inches,at 800rpm. I might be able to pull 11 or possibly 12, if I crank 18*initial into it.
I'm also not saying your PV is wrong.
But I am suggesting its worth a look, and easy to get to and check,and the PV-plug test,will tell the tale.
