lil red
thinking about pulling the 360 out of the express truck and looking for advice or suggestions on a camshaft.
The engine now is :
original 79 360 block
cast flattop pistons, about .090 below deck (maybe 8.5 - 8.7 cr, i think the factory dished yielded about 8-1)
rhs indy heads with ss 1.92 intakes and 1.6 -1 adjustable rocker arms
ld 340 intake
750 street demon carb
mopar .450.455 268 272 duration camshaft
shorty headers from a mid 90s dodge ram magnum with 2.5 inch headpipes and 2.25 inch tailpipes out the stacks
Transmission is the original 727 loadflite with a factory equipped 2200 stall
3.55 gears with a 28 inch tire
The truck is primarily street driven and 6000 rpm would be about the most I turn it. The truck used to have an old set of j heads on it a few years ago, and it was a pretty fun combination that pulled strong to about 5300, but with the new heads the truck seems to want to pull above that rpm but seems limited by the camshaft. I maybe wrong ( hence the needed advice), but the mopar cams seem to work well with the older factory gear, but im wondering if the new heads should take advantage of the higher lifts and agressive profiles of modern grinds - hughes, lunati, comp, etc.
I had a post a while ago about a stroker, but in reality a nice 375 - 400 horse 360 would be good with the amount i use the thing. I came into posession of a set of speed pro h116cp pistons which should give about 10 - 1 compression with the 62cc head.
with the bump in compression should i move up a step in duration to a 274, A lot of guys on here run the comp xe274 which seems to a preferred line, but then again most have an abody instead of a 4500 lb truck.
just wondering what you all think,
The engine now is :
ld 340 intake
