Cam Suggestion for a 440-499 stroker
Big Block A body Tech
  1. Lil Demon
    Lil Demon Well-Known Member
    254
    103
    Mar 23, 2011
    Laredo, Texas
    Local Time:
    3:38 AM
    I got a customer at my shop and I've been upgrading his brakes and suspension but then we got to talking about his engine and how it was setup. I could tell it needed carburetor tuning and timing re-curved. I did that and it runs a lot better but I can't do much for it's driving manners. I finally got the cam specs from him and for a street cruiser it is overkill IMO. Like I said It's a stroked 440 to a 499, Edelbrock RPM heads, SRP pistons netting him 10.5:1 Intake is Edelbrock TM7, The cam is a Comp Cams Hydraulic Roller 23-713-9 with .549/.544 lift and 242/248 duration on a 110 LSA. He's got the 4.10 gears out back and what seems like a 1200 stall converter LOL. As you can imagine just putting in gear kills the idle by 350 rpm and there's not much low speed torque to be enjoyed. You need to wind up the motor to make some steam.
    I'm suggesting a cam closer to lower 230 duration or high 220's and of course the Edelbrock Performer RPM intake to help him enjoy a healthy production of low speed torque for a very stout street cruiser ocassional street brawler setup he intended. What say you guys?
  2. forphorty
    forphorty Well-Known Member
    696
    283
    Jan 19, 2006
    Local Time:
    3:38 AM
    I would leave the engine alone and change the converter.
    • Agree Agree x 7
    • fishmens67
      fishmens67 Well-Known Member
      8,380
      6051
      Nov 10, 2012
      idaho
      Local Time:
      3:38 AM
      The Rpm intake would be a good choice.
      If it is a 499, it should be more responsive than you're implying.
      The cam is pretty tame already.
      RPM intake and convertor change should fix it up.
      • Like Like x 1
      • Lil Demon
        254
        103
        Mar 23, 2011
        Laredo, Texas
        Local Time:
        3:38 AM
        You know I think I have a 727 stall converter laying in my shop. I’ll give it a shot to see how it responds and if the customer is happy with it. Good suggestions as always. Thanks
        • Like Like x 1
        • AndyF
          AndyF Well-Known Member
          1,781
          1900
          Feb 23, 2009
          Oregon
          Local Time:
          1:38 AM
          That cam might not be perfect but it should be okay with 4.10 gears. I have a 246/246 cam in the 512 in my Duster and it runs fine. I think the trick is the converter. I have a tight 10" converter in my Duster but the stall speed is still up in the 3500 range. The TM7 intake might not be doing him any favors. If there is room under the hood and in the budget then I'd switch it to a Trick Flow intake. I don't think I'd use a Performer RPM on a 499 inch engine but you could if he is just driving it around town. Try changing the converter first and see how that goes then maybe think about a different intake. A slightly smaller cam might also be in the cards but I wouldn't go much smaller, maybe just a few degrees.
        • mbaird
          mbaird mbaird
          6,222
          3081
          Dec 10, 2005
          boise, Id
          Local Time:
          2:38 AM
          I run a 246/250 on a 108 with .648 lift in a 408 running a 4 sp and it is mild enough. I would think that cam in a 500+ CI motor should be a pussy cat.
          AND A TIRE SHREDDER !
        • Lil Demon
          254
          103
          Mar 23, 2011
          Laredo, Texas
          Local Time:
          3:38 AM
          You know I failed to mention he intends to go to a 3.55 in the near future, again he wants a cruiser. I recurved the distributor and set it at 34 degrees total and rejetted the carburetor and it turned into quite the tire smoker vs the lazy launches it did when it first came in.
        • Rmoore
          Rmoore Well-Known Member
          417
          249
          Nov 14, 2018
          Gun Barrel City, Texas
          Local Time:
          3:38 AM
          Did you change the converter yet ??
        • Lil Demon
          254
          103
          Mar 23, 2011
          Laredo, Texas
          Local Time:
          3:38 AM
          Nope I posted this as I was closing shop. We will give it at shot tomorrow if our schedule permits. I’ll let you guys know how it goes. It’s a B-Body but I just posted here since I’m familiar with the community cause of my Demon.
        • Rmoore
          417
          249
          Nov 14, 2018
          Local Time:
          3:38 AM
          cant wait to hear how the converter changed this beast into a Mega Beast lol !!
          • Like Like x 1
          • famous bob
            famous bob mopar misfit
            17,504
            6977
            Aug 14, 2011
            okla
            Local Time:
            3:38 AM
            That cam is smaller than mine , I dont have a problem w/ it !! His convertor should match the cam specs tho-------------
          • PRH
            PRH Well-Known Member
            2,599
            3942
            Dec 14, 2018
            So. Burlington, Vt
            Local Time:
            4:38 AM
            Have a proper converter built for the combo.
            If it has the hood clearance, but an RPM intake on it.
            You didn’t mention it, but hopefully it has headers on it.
            If not...... then it’s the wrong cam.
            For a strictly “cruiser” type build with a tight-ish converter and 3.54’s, the cam could stand to be a bit smaller.
            • Like Like x 1
            • Lil Demon
              254
              103
              Mar 23, 2011
              Laredo, Texas
              Local Time:
              3:38 AM
              Update:
              I haven’t swapped in the stall converter yet but I did have a brand new Mopar wedge intake so I swapped it in end it instantly tamed the idle and tuned a lot easier, right now I’m just fixing his transmission kick down rod which is all in an odd shape And fixing his throttle linkage because it never actually saw wide-open throttle LOL. Curiously now the idle only drops around 220 RPM When engaged into gear versus 300+ with the single plane
            • Lil Demon
              254
              103
              Mar 23, 2011
              Laredo, Texas
              Local Time:
              3:38 AM
              It feels like a totally different car with the Mopar Wedge intake. Gobs of low end torque and extremely responsive. Lights up all three gears still using the low stall converter . Damn car caught me off guard when I did a straight launch! Glad we’re upgrading his suspension cause it definitely needs it now. It flat out will not go straight! 1C231FF1-4788-4DEE-A7C9-A547BB19ED0C.jpeg
              • Like Like x 1
              • Lelo Dart
                Lelo Dart * FABO Gold Member
                1,475
                434
                Oct 10, 2012
                Knob Noster MO.
                Local Time:
                3:38 AM
                That wedge intake the same as the RPM intake with different lettering on it.
                • Like Like x 1
                • PRH
                  2,599
                  3942
                  Dec 14, 2018
                  So. Burlington, Vt
                  Local Time:
                  4:38 AM
                  Exactly.
