[FOR SALE] cams convertas and few more parts
earthmover
in the tire smoke
nc
9.5 dynamic race verta had behind my 345 would go 45 5000 very good verta did mostly street racing
600.00 plus the ride
8 inch turbo action would go 5 5500 behind 345 same as above street race
lunti solid roller 3 bolt big block
53799
lun 37 up 73 ur 73
282@50
457 lobe
685 lift 1.5 rocker
731 1.6 rocker
26 lash
175.00
cam motion solid roller
I'll get spec tomorrow or weekend
175.00
440 source bullet fly wheel used to break new motor end that's it 100.00
aluminum valve covers 100.00
all parts are plus shipping
these are parts I'll never use again
have a few more I need get pictures of to post
also have a 10 inch b&m verta bought used never used it 200.00
Interested in Billet Flywheel to break in my motor when it's done. Mailbox is full. My email !(no emails in public forums, in the rules. (Thank you)
Thanks,
Jay
(Or phone numbers)
Text Ok
ok bigmike54
Thanks,
Jay
Thanks,
Jay
(Or phone numbers)
Text Ok
is your crank 6 bolt I forgot mines hemi bolt deal I believe
but will verify
Maybe interested in 9.5 and 8 inch converters. Are they for 904 or 727's, How much? Thanks.
What are the specs of the motors you ran those cams in?
Been looking for a solid roller.
This is what I'm working with:
383 with 12.5-1 compression, tunnel ram with dual 750dps
5000 stall converter RMVB 727
8-3/4 4.11 gears
29in tall tires
3800lb car
8-3/4 4.11 gears
29in tall tires
3800lb car
was in a 451 never really made good track pass shift noid wire was off
then trans pump was leaking
then found out that crankshaft specialties in Tennessee if I remember right beat me out of my money to fix the crank
was found to be cracked after he calm to fix it
had great power I have a video where the shifter didn't shift I'll try to post
it's not letting me post it
I can email it to you if you inbox me your email
Your inbox is full.
Fellas, phone numbers and e mail addresses have been removed here for your internet security. They are against the site's sale rules. Thanks
Note: I sent @earthmover a message to clean his inbox.
cam motion cam specs
273 283
737 int
705 ex
112 love sep
108 centerline
24 lash
