Just what are "well-sorted LS street engines" anyway? The whole question is to damn vague for me.
Just look at all his posts. He's the most vague and convoluted person you'll ever see. lol
The 1200hp ls i referred to earlier has speedmaster heads on it.Horsepower and Speedmaster heads do not go together....
Like what you build sir.Just what are "well-sorted LS street engines" anyway? The whole question is to damn vague for me.
There is a 6.2 LS sitting in my driveway backed by a 8 speed tranny in a 3750 lb car. Yes, you can build a N/A 400 to beat it.Like what you build sir.
An LS engine (6.2 Liter-408ci, LS7 -entry level, but without problems, if 408 stroker built, best probable cam, include their fuel injection wiring harness.-the real top end entry level contenders-allot like the way your family built big blocks!
I think the answer is he needs a 787 HP 451 and you have one. lolJust what are "well-sorted LS street engines" anyway? The whole question is to damn vague for me.
You should have seen his 361 build in 2011!!I think the answer is he needs a 787 HP 451 and you have one. lol
They had many good builds including a 426 small block everyone seems to have forgot about.You should have seen his 361 build in 2011!!
or Kansas.... 9k rpm'sThey had many good builds including a 426 small block everyone seems to have forgot about.
I wonder if someone showed up at their shop door with a fist full of cash if they would come out of retirement for one more build.
He needed to be forgot about.or Kansas.... 9k rpm's
sorry, I had to....He needed to be forgot about.
The only thing turning 9000 RPM was his brain coming up with his BS.
I wonder if he ever got done casting his new designed cylinder head. lol
I have run up against my share of big boost small motors. They are very fast for season one. But fall apart. Even the Hellcats don't last long on any race circuit. My 451 is 10sec flat. Single carb. N/A. I saw a Pro charged Mustang running low 9s. Never saw him again. I would be scared to throw any power adder to my Duster. Maybe a single 200 shot? But that's it. Power adders are for cheaters. Lol.
Please tell us a little about your car and motor.I have run up against my share of big boost small motors. They are very fast for season one. But fall apart. Even the Hellcats don't last long on any race circuit. My 451 is 10sec flat. Single carb. N/A. I saw a Pro charged Mustang running low 9s. Never saw him again. I would be scared to throw any power adder to my Duster. Maybe a single 200 shot? But that's it. Power adders are for cheaters. Lol.
Well I've built 383 Chevies and 347 Fords but never a LS engine, so..............having no experience to fall back on I should stay out of this discussion.Like what you build sir.
Oh, and...........I've never built a 361, not in 2011......not ever. Now my Dad did build one in 1959, ran over 150 mph at Bonneville that year.You should have seen his 361 build in 2011!!
Sorry for the delay. Anyways some basics about 13.5 - 14.0 comp a modern solid lifter cam about 268 - 274 dur @ .050 some decent rods (eagle or such) single plane tall manifold 950 carb. should be a killer set up, now a 8 inch convertor a set of small slicks should be over the top for most ls's. It would be a cheap build and easy on parts. Look for used convertor, manifold and carb. slicks and use a trans shield. You will just love it. And a stroker is always great if you got the extra $$$. And it is fully streetable.If it's built for a purpose and if you don't mind spending the $ on good fuel you can do it rather cheap. You really are not going to drive it much so the fuel will not kill ya. I'll be right back.
Very very nice.3000 lb '74 Duster. The motor you heard. Cam profile is pretty tame with flat mechanical lifters at .590 lift. Someone before me made a very clever steel tilt front end. That makes any maintenance and cool down certainly easier. 727 reverse manual valve body trans. To 8 3/4 Mosier axled w/spool rear. 4.56:1 gears. On 30x10.5 slicks. 8 point cage. MSD AL with a 2 step line lock launch control (no trans break) launching at near 3000 rpm. Shift at 6500. 7500 redline Rev limitor.
It's not street ready with lights/signals or horn. But could be with minimal effort
My 451 is close to thous numbers. I believe a little less compression. (Block was not decked to build. Thus pistons are a tick in the hole.) I'm guessing around 12.5:1. Running to a 1050 E-85 metered Holley 4150 style carb. (E-85 to accommodate the higher compression.)Sorry for the delay. Anyways some basics about 13.5 - 14.0 comp a modern solid lifter cam about 268 - 274 dur @ .050 some decent rods (eagle or such) single plane tall manifold 950 carb. should be a killer set up, now a 8 inch convertor a set of small slicks should be over the top for most ls's. It would be a cheap build and easy on parts. Look for used convertor, manifold and carb. slicks and use a trans shield. You will just love it. And a stroker is always great if you got the extra $$$. And it is fully streetable.
