Can a 400BBM w/cheap aluminum heads compete/dominate against the street LS?
Big Block A body Tech
  1. greymouser7
    greymouser7 Vagrant Vagabond “Veni Vidi Vici”
    3,537
    2808
    Apr 17, 2010
    78002 down the road from Atascosa, Texas
    Local Time:
    7:00 AM
    Why? Planning the most power on a budget. Perhaps iron906 or 346 heads would get more flow than entry level ($550) assembled aluminum heads that are then ported.
  2. RustyRatRod
    RustyRatRod I was born on a Monday. Not last Monday. FABO Gold Member
    79,466
    57904
    Jun 7, 2010
    Georgia
    Local Time:
    8:00 AM
    The slant six has one head.
  3. greymouser7
    3,537
    2808
    Apr 17, 2010
    Local Time:
    7:00 AM
    There is an entire CULT Following of fast ugly cars, it evolved/branched off into ratrods. You will be cool. This isn’t like the clicks in grade school with the best dressed kids-nobody (relatively) has these cars, and even those that do have the common-CRAP Chevies & mustangs, not original, more exotic cars.
    Brother, YOU are the cool kid now. Don’t give a truck about some jealous pansy and his mouth. Even Rumblefish had to educate some MORON about the type of engine a guy had because the moron ran his mouth. Those fools should not have your ear, EVER!
    • Agree Agree x 1
    • greymouser7
      3,537
      2808
      Apr 17, 2010
      Local Time:
      7:00 AM
      ROFL
    • RustyRatRod
      79,466
      57904
      Jun 7, 2010
      Georgia
      Local Time:
      8:00 AM
      I knew that'd grab you. lol
      • Like Like x 1
      • greymouser7
        3,537
        2808
        Apr 17, 2010
        Local Time:
        7:00 AM
        Sir,
        remember AVgas has paraffin, which creates carbon deposits in the chamber and onto the piston heads.
        RRR says revving up the engine hot burns that up. I bet water injection would help too.
        I believe enough carbon buildup would add heat, perhaps uneven heat in the chamber-potentially creating opportunities for detonation.
      • RustyRatRod
        79,466
        57904
        Jun 7, 2010
        Georgia
        Local Time:
        8:00 AM
        ummmmm......I did?
      • Sublime one
        Sublime one 72 Demon FABO Gold Member
        6,015
        13375
        Mar 17, 2018
        Fargo
        Local Time:
        7:00 AM
        Well said good Sir! I just get tired of listening to all the haters on my Cuda. It has 73 tail panel because I like round tailights, the whole front of car is fiberglass including the dash! Toggle switch of course, nose is from a 70s mold because I like the 1970, grill and fenders are 71 cuz I like the gills! Cal trac and a stroked 440 running mega squirt EFI. Typicall fiberglass cracks all over front from hard landings and I painted it in our barn. Hosed the hung some tarps, hosed the place down and rocked me some Sublime! Steering wheel gets unceremoniously tossed on dash, every show I have ever taken it to just to show folks the other side of our hobby, I get bombarded with the “ how could you do that to a Cuda?” My standard reply is.. thats why your key don’t fit!
        • Like Like x 1
        • Thanks! Thanks! x 1
        • pishta
          pishta I know I'm right....
          21,388
          10777
          Oct 13, 2004
          Tustin, CA
          Local Time:
          5:00 AM
          No. LS cylinder heads are awesome. sorry.
          • Sublime one
            6,015
            13375
            Mar 17, 2018
            Fargo
            Local Time:
            7:00 AM
            You want butt ugly and ruthlessly efficient here ya go. Toggle switch dash, reference tape on steering wheel, engine bay black with EFI on a stroked 440! I love this car! It has eaten its share of LS rigs, there is always someone quicker but in the end our record against LS platform is pretty good. A lot of guys out here have the HP but can’t get it on the ground. I am only at 630HP and often times at a disadvantage with regard to HP but if your car is sorted out it sure helps. You have to make a lot of mistakes to get it sorted out!
            • Like Like x 4
            • Thanks! Thanks! x 2
            • rumblefish360
              rumblefish360 I have escaped the evil Empire State! FABO Gold Member
              41,707
              13953
              Jun 21, 2005
              Florida
              Local Time:
              8:00 AM
              Because not all OE heads are created equal or port out equally. Then there is the variable of valve size choices and there dimensions. So let’s start at the beginning.
              I’ll skip purchasing the OE heads cost and assume you or someone else reading has a set on there engine now. The cost of rebuilding and porting an iron head will more than likely be more expensive than an aluminum head. The condition of the head is a variable to start with and what’s done to it is another variable. Then add the porters cost.
              IF you purchase a set of TF or other heads of a good known reliable and trust worthy source for there quality and air flow reports, it will more than likely be the best and most cost effective way to simply bolt on power.
              You already have the heads now BUT porting them may not be the cost effective route vs a reputable set of CNC heads OOTB. Something like a Black Friday sale and then worked on would more than likely play into your favor.
              Just look back to the multiple “C” program I listed earlier.
              • cojohnso
                cojohnso Well-Known Member
                361
                431
                Mar 25, 2019
                Minneapolis, MN
                Local Time:
                7:00 AM
                Not sure of this year's schedule. Here in Minnesota it's still too cold. Will be for the next month. At minimum.
              • PRH
                PRH Well-Known Member
                3,568
                5264
                Dec 14, 2018
                So. Burlington, Vt
                Local Time:
                8:00 AM
                My take on it is........ don’t worry about what everyone else thinks.
                Come up with a plan....... build it...... install it...... see how it all shakes out.
                There will be some LS builds that are slower, some that are faster.
                Just like everything thing else out there.
                The only way to really learn how this stuff works is to actually build them.
                • Agree Agree x 5
                • Like Like x 2
                • cookietruck
                  cookietruck Well-Known Member
                  1,062
                  248
                  Jun 25, 2012
                  alkdfnoi
                  Local Time:
                  7:00 AM
                  ^ yep.
                  also, that article that IQ52 posted had some builds that were 400ci, making alot of power too. No details but goes to show you can make some power without the stroker crank. get the heads done right and find a piston that will give you decent compression...
                • MOPAROFFICIAL
                  MOPAROFFICIAL FABO Gold Member FABO Gold Member
                  9,406
                  8748
                  Jun 1, 2016
                  Oceanside ca.
                  Local Time:
                  5:00 AM
                  Speed disaster 4.25 crank
                  Mostly...the heads are where your problem is. Porting isn't cheap.
                  CID is cheaper.
                  451 LD with decent heads will dust a 408 ls...but in what..? A sleeper race car? bone stock? Neon ground effects and mixed up bolt ons by a teenager...?
                  Imo/ime A good small block 410 will put a hurting on them when setup right... but pick where. Light to light. Freeway or .. cause you cannot have it all or cheaply at least .
                  • Like Like x 2
                  • RustyRatRod
                    79,466
                    57904
                    Jun 7, 2010
                    Georgia
                    Local Time:
                    8:00 AM
                    They also did a low compression 400 build that was quite impressive.
                    • Agree Agree x 1
