Can I remove the weight on my torque converter
Transmission and Drivetrain Tech
  1. doopdoop67
    doopdoop67 Well-Known Member
    284
    91
    Sep 8, 2015
    pacifica california
    Local Time:
    2:04 PM
    Hey guys, I just bought a Hughes 3500 stall for mg dart. Installed it and realized the weight is pushed up against the flex plate which is making the flex plate rub the back of the engine. It’s a 360 engine with a 727. My old converter didn’t have a weight on it and I just want to make sure I can remove the weight off the new converter. I know a 360 is externally balanced so I can’t remember if you need a balanced converter or not. Thanks!
  2. toolmanmike
    toolmanmike FABO MODERATOR Staff Member FABO Gold Member
    58,877
    45997
    Jan 18, 2006
    Iowa
    Local Time:
    4:04 PM
    You can have a neutral balanced converter as long as you run the correct flex plate. Correct me if I am wrong here guys.
    • Agree Agree x 3
    • Like Like x 1
    • 72Dart6pack
      72Dart6pack Harder Better Faster Stronger.
      4,444
      4691
      Feb 1, 2016
      Roseville Michigan
      Local Time:
      5:04 PM
      Sure just rip it off.
      • Like Like x 1
      • Demonracer
        Demonracer 71 Demon 00 Ram 16 Chrysler 300S 05 Caravan FABO Gold Member
        5,027
        3021
        Jan 31, 2010
        Cleveland, Texas
        Local Time:
        4:04 PM
        Use the FP that TMM shows & take the weight off.
        • Like Like x 1
        • Thanks! Thanks! x 1
        • doopdoop67
          284
          91
          Sep 8, 2015
          pacifica california
          Local Time:
          2:04 PM
          That’s the flex plate I have. Thanks
        • doopdoop67
          284
          91
          Sep 8, 2015
          pacifica california
          Local Time:
          2:04 PM
          Perfect, I have that flex plate already. Thank you
        • Outsder
          Outsder way back when
          137
          65
          Sep 5, 2019
          Northwest
          Local Time:
          2:04 PM
          One or the other, but not both. Either run the convertor with wts. on a stock like flex plate with the clearance for the weights, or run the specific application solid/clipped external balance flex plate with no convertor wts.
