A guess would be because they market it as a fuel-controller only with everything built in and adaptable to any carbureted engine. Controlling spark timing would be very dependent on the engine family. You can find the Holley Commander 950 manual online to read-up. They only allow controlling spark for a GM 8-pin HEI (1985-95), which requires a special adapter cable. Also much info on the Megasquirt site. Most people who upgrade their A-body ignition use the GM 8-pin HEI since easiest and cleanest install, plus a wicked spark. Even hotter is the LSI coils (1 per cylinder), but you are beyond the Commander 950 then.If it really is that simple, why the heck is FiTech not offering knock sensing in their units?!
You just added another HAVE TO do thing to my list while the car is on stands. ThanksBringing up this old thread, I want to ask how much space I have behind the drain plug for the coolant in a stock 383 block. I just pulled the plug, bunch of crud behind it, but I don’t want to be poking too far yet. If somebody could tell me how much space I have I appreciate it.
I figured while I’m down there underneath my car, I might as well replace the power steering box.You just added another HAVE TO do thing to my list while the car is on stands. Thanks
Time to spring for a can or two of degreaser.There was only a thin layer of rust, it was easy, just a tap, it came loose.
I agree, I should pull the engine and give it a good scrub down.Time to spring for a can or two of degreaser.
Thanks to you I learned this not long ago here with pictures, thank you TM.Most of the block drains are full of casting sand. Not a real good place for a sender.
Me? Yes.You gunna use a radiator petcock or ?
Both sides, are you?You gunna use a radiator petcock or ?
Inside my block (coolant and oil), is a heck of a lot cleaner than the outside.Time to spring for a can or two of degreaser.
Yeah both sides, I'm gunna give it a shot. Seem to recall I wasn't able to remove the plugs 25 years ago. Doesn't mean I won't try again.Both sides, are you?
