Can this be duplicated with a 5.9 build??
Small Block Mopar Engine
  1. HankRearden
    HankRearden Well-Known Member
    136
    86
    Sep 11, 2017
    PA
    Local Time:
    8:06 AM
    310 hp at 4100 rpm 450lbft torque at 2400 rpm.
    These are the published hp and torque figures of the cast iron 8.0 v10 Chrysler used in the 90's.
    Having had one of these that rotted out before its time I have missed the power for towing.
    But I see some of the amazing 5.9 builds published on this forum and it made me wonder if instead of building for horsepower maybe some of you much smarter than me would entertain an idea of building for something to haul the race car or boat.
    • Like Like x 1
    • 67Dart273
      67Dart273 FABO Gold Member FABO Gold Member
      54,153
      23922
      Oct 14, 2010
      Idaho
      Local Time:
      5:06 AM
      ...........Or figure out how to swap a 440 into one. No, I haven't.............
      Frankly, if you are towing, there is only ONE correct answer. It is an inline six and is not built by Chrysler They are however, 5.9 LOL
      • Agree Agree x 8
      • Like Like x 2
      • dano
        dano Evil Handy Man
        4,318
        2176
        Aug 22, 2005
        Gresham, Oregon
        Local Time:
        5:06 AM
        Maybe with a 4" crank and a cam that's focused on low RPM torque. A turbo or supercharger would get you there on a gas 5.9.
        I consider towing a turbo diesels job. Once you've towed with one you'll never look back but boy do you pay for them up front.
        • Agree Agree x 5
        • sireland67
          sireland67 FABO Gold Member FABO Gold Member
          9,930
          4361
          Oct 27, 2010
          WV
          Local Time:
          8:06 AM
          I built this 5.9 with torque for a truck, it pulled great.
          The engine acted just like comps desktop dyno said it would.
          Look at the off idle torque.
          • Like Like x 4
          • gzig5
            gzig5 Well-Known Member
            2,172
            2604
            May 3, 2018
            Mequon, WI
            Local Time:
            7:06 AM
            I think that would get'r done in about anything.
            • Agree Agree x 2
            • 273
              273 Well-Known Member
              3,887
              1630
              May 14, 2012
              Ontario
              Local Time:
              8:06 AM
              basically torque is displacement, if it's NA or power adder and hp is how much it can displace over time. or said another way torque is one powerstroke and hp is all the powerstrokes added up.
            • HankRearden
              136
              86
              Sep 11, 2017
              PA
              Local Time:
              8:06 AM
              Wow, is that some secret recipe? Thats amazing.
            • AJ/FormS
              AJ/FormS 68 Formua-S fastback clone 367/A833/GVod/3.55s FABO Gold Member
              22,789
              9819
              Jan 19, 2014
              South-Central Manitoba,Canada, 900ftelevation
              Local Time:
              7:06 AM
              That's a hard target for a normally aspirated 318 cuber, Especially for a low-compression example that might barely crest 240ftlbs.
              But here is a 5.2M with a keg intake. Notice the Torque is already up at 3200, and the power-peak is already up at 4400. And this is in a 9.0/9.2 compression engine. When you take the EFI/keg off it, you will lose that lovely torque spike.
              To even get close to those V10 numbers with 318 normally aspirated cubes,
              IMO, that engine will need a chitload of compression, probably specialized porting, and very specific intake/exhaust tuning.
              But it should be easy with a super charger or maybe even with turbo charging, on any old low-compression teener..
            • AJ/FormS
              22,789
              9819
              Jan 19, 2014
              Local Time:
              7:06 AM
              I got to see one of those torn apart recently. The bore looks close to 4 inches (I didn't measure it), but if it is, then, to make 5.9liters from just 6 cylinders, it would need a stroke of ~4.78 inches. That comes to 60 cubic inches per cylinder. And they only "fire" three cylinders per revolution..... Said to be very smooth.
            • 67Dart273
              54,153
              23922
              Oct 14, 2010
              Idaho
              Local Time:
              5:06 AM
              The "seat of the pants" torque they deliver is spectacular. It just MOVES, no fuss, no muss.
              • Like Like x 1
              • DMC_78
                DMC_78 Member
                24
                6
                May 26, 2021
                Canada
                Local Time:
                8:06 AM
                I am curious too…
              • mbaird
                mbaird mbaird
                8,578
                5444
                Dec 10, 2005
                boise, Id
                Local Time:
                6:06 AM
                Cummins weigh around 900 lbs . That is a big hurdle if you have a 1/2 ton .
                Aim for 450 ft-lbs around 3000 and match the gearing .
              • Scody21
                Scody21 Just send it
                1,561
                1794
                Jul 17, 2019
                Southwest Washington Coast
                Local Time:
                5:06 AM
                What cam is that? Looks badass for a magnum...
              • hotrod swinger
                hotrod swinger Well-Known Member
                359
                235
                Mar 6, 2020
                Sooke
                Local Time:
                5:06 AM
                I thought he was asking about a 360 (5.9), in which case hitting 400 hp in a mild build is definitely doable.
                • Agree Agree x 3
                • YY1
                  YY1 Well-Known Member
                  9,009
                  4794
                  Oct 11, 2011
                  FL
                  Local Time:
                  8:06 AM
                • YY1
                  9,009
                  4794
                  Oct 11, 2011
                  FL
                  Local Time:
                  8:06 AM
                  That cam lift sounds low to me, maybe those are the 1.5 ratio numbers.
                • barbee6043
                  barbee6043 barbee 6043 FABO Gold Member
                  16,433
                  9842
                  Jul 20, 2008
                  Shepherd, Texas ( SE Tx)
                  Local Time:
                  7:06 AM
                  Gas pickup for towing??? Torque, right gear.
                • rumblefish360
                  rumblefish360 I have escaped the evil Empire State! FABO Gold Member
                  43,344
                  15452
                  Jun 21, 2005
                  Grant Valkaria, Florida
                  Local Time:
                  8:06 AM
                  I’ve eyeballed these packages before and I think there pretty good. It is a valve spring (if even needed) & cam swap away from a very nice mild performance engine or in this case, a tow engine.
                  IDK, perhaps something like a 210@050 intake duration?
                  It’s small enough not to need a converter change but effect the low end power a good bit.
                • mbaird
                  mbaird mbaird
                  8,578
                  5444
                  Dec 10, 2005
                  boise, Id
                  Local Time:
                  6:06 AM
                  Towing takes more than just HP and Torque. An engine that makes 600 hp and 700 ft-lbs for 10 seconds on a dyno does not translate into a good tow motor . Heat generation and rod angle generated stress etc comes into play .
                • AJ/FormS
                  22,789
                  9819
                  Jan 19, 2014
                  Local Time:
                  7:06 AM
                  OOps yur right, yeah 430torque is doable with a 5.9, but I can't see it at 2400 normally aspirated.
                  Sorry I screwed up.
                  • Agree Agree x 1
                  • AJ/FormS
                    22,789
                    9819
                    Jan 19, 2014
                    Local Time:
                    7:06 AM
                    • Like Like x 1
                    • my68barracuda
                      my68barracuda Well-Known Member
                      2,336
                      2263
                      Dec 6, 2009
                      Indianapolis IN
                      Local Time:
                      8:06 AM
                      Exactly, the OP was asking about a motor that would equal the 450 ft lb torque at 2400 rpm. To get that torque at that low of a rpm with a less cubic inches, he will need boost, and I am thinking a positive displacement supercharger or an undersized turbo that spools early would be the way to get there.
                      • Agree Agree x 1
                      • AJ/FormS
                        22,789
                        9819
                        Jan 19, 2014
                        Local Time:
                        7:06 AM
                        The thing with the Jegs engine is that the 410 ftlbs at 3000 is WFO.
                        As is the rest of that graph..........
                        Not particularly cruise-friendly.
                        But ya gotta admit; it has a heckuva loooong flat power curve. At 3800 it is already at 95% of peak, and the power just keeps on going and going and going, lol. Then at 4900, the rate of decline of the torque curve eases, and the power actually begins to climb again? IDK but it is significant.
                      • rumblefish360
                        43,344
                        15452
                        Jun 21, 2005
                        Local Time:
                        8:06 AM
                        30 lbs of Tq. is a sizable amount more for the engine is question. I again say, the right cam will do it. Even more so due to the size of the cam in the engine as delivered. AKA = TINY!
                        Also! Pay attention to Mr. Vizards exhaust thoughts!
                      • 67autocross
                        67autocross A new iron curtain drawn across the 49th parallel
                        1,711
                        1175
                        Jul 23, 2010
                        Winnipeg
                        Local Time:
                        7:06 AM
                        310 hp at 4100 rpm 450lbft torque at 2400 rpm...I would say it could be done with at 360 inches with the right parts but it would need good heads...if you use a 4 inch crank it would be a lot easier...
                        • Agree Agree x 1
