Can you install a shorter A body 833 into a 71-74 B-Body?
Manual Transmission & Clutch Discussions
  1. greymouser7
    greymouser7 Vagrant Vagabond “Veni Vidi Vici” FABO Gold Member
    3,260
    2570
    Apr 17, 2010
    78002 down the road from Atascosa, Texas
    Local Time:
    1:55 AM
    Or will the brace (that the torsion bar mounts to) sit too far back on the short shaft?
  2. Rainy Day Auto
    Rainy Day Auto Princess Valiant FABO Gold Member
    21,156
    11660
    Dec 14, 2011
    Colorado
    Local Time:
    12:55 AM
    I would have to call a no on this ......the A-body trans puts the shifter mount behind the crossmember and the B-body (front mount or W bench) puts it in front of the cross member so that's a huge conflict. If you used the rear mount (e-body location) for bucket seats with or without console ...the a-body shifter point will be too far forward.
    I am sure someone can fab it and make it work but all depends on what kind of project you want to run here.
    B/E transmission are way more common than A-body units.
  3. Daves69
    Daves69 FABO Gold Member FABO Gold Member
    4,701
    2826
    Feb 20, 2011
    WestOfChi
    Local Time:
    1:55 AM
    I'd agree with Rainy it's possible but you going to have a shifter location and driveshaft length issue.
    With so many b-body unit out there I would think a trade be available.
    An adapter for b-body trans into an A-body can give an idea for the other way I suppose.
    http://www.bigblockdart.com/techpages/abconv.shtml
    • Like Like x 1
    • greymouser7
      3,260
      2570
      Apr 17, 2010
      Local Time:
      1:55 AM
      The shifter has been sorted out enough to work.
      The transmission crossmember is already cut to fit now (as of this evening), floor pans cut up anyways to be replaced, did not have to touch the torsion bar crossmember.
      Isn't the A/F body trans the same length as the 904 auyomatic it replaced?
    • 67Dart273
      67Dart273 FABO Gold Member FABO Gold Member
      41,664
      9317
      Oct 14, 2010
      Idaho
      Local Time:
      11:55 PM
      Yes same as 904. Problem is the location of the shifter mount. "Maybe" you could do it if you were willing to "high mount" whatever the supershifter Hurst used to have I don't remember what it was.
    • AJ/FormS
      AJ/FormS 68 B'cuda fb, Form S clone ... 367/A833/3.55s
      17,549
      5942
      Jan 19, 2014
      South-Central Manitoba,Canada, 900ftelevation
      Local Time:
      1:55 AM
      The shifter was already too far forward in A-bodies, IMO. Third could be a knuckle-buster.
      I moved mine WaaaaY back and up.
    • greymouser7
      3,260
      2570
      Apr 17, 2010
      Local Time:
      1:55 AM
    • greymouser7
      3,260
      2570
      Apr 17, 2010
      Local Time:
      1:55 AM
