Kllrbee
Not sure if I should post this here or in Fuel/Air.
This question is for the six pack guys that have a good eye for the secondary springs.
I just started refamiliarizing myself with the 6 packs carbs and am starting to get them dialed in. I had a slight bog when Id get on it, not too bad, but noticeable. Adjusted floats and set idle a/f by idle and vacuum gauge. Next step I wanted to check before removing the carbs and checking acc pump, power valve, and jets is the secondary springs.
Honestly though, I cant tell which ones they are...lol. They could be the plain and just dirty or they could be the black and paint worn off.
From my understanding, it goes white, yellow, purple, plain, brown, black...light to heavy.
So theres probly a pretty big difference between plain and black.
Also, I realize that I could just get a new spring kit for cheap and I most likely will. But it would be nice to know which springs I have right now as a starting point.
Does anyone have a good enough eye for these springs to tell from its length or number of spirals which spring this is?
I know, kind of a weird question, but I figured it was worth a shot.
Thanks
Thanks
