I was digging through the PO's paperwork and found the production broadcast/build sheet. I wanted to decode it but it doesn't fully match the layout on mymopar.com. There are also some number-only codes under the "build codes" section (lines 3-5) that don't seem to match up with anything I've seen. I think the "R" plant location means the car was built in Windsor, Canada which might explain why the paperwork is a bit different. Can anyone tell me how to decode the whole thing?
Here is a link to a high resolution image.
