Cap for return line
DART66GT
62 Lancer GT - B Body 8 3/4
Connecticut
Who makes a fuelproof cap for my 1/4 inch return nipple on my sending unit. Don't want to do bolt plug in line.
Is the sending unit installed? If not and you're sure you will never use the return line you could crimp it and solder, braze, or weld it up.
I have these at home just wasn't sure if they held up to gas
They dont. They do, but not for a permanent fix. They will fail.
Rubber hose and a ball bearing.
Hello All
Rubber hose made from rubber
Cap made from rubber
You choose your rubber
Eventually everything fails that is why we restore cars.
Happy Mopar :)
Arron
Color/Finish: Black
Inside Diameter: .14 In.; .22 In., .32in., .38 In., .21 In., .26 In.
Material: Rubber
Package Contents:
5/32" Cap, 7/32" Cap, 5/16" Cap , 3/8" Cap, 3/16" Caps, 1/4" Cap
Package Quantity: 30
Packaging Type: Tray
I'll use the vacuum cap for now so I can keep the project moving then I'll probably plug a piece of fuel injection line.
