Car turns when rolling backwards
Suspension, Steering and Chassis
  1. gm1236
    gm1236 Well-Known Member
    136
    52
    Aug 3, 2013
    Massachusetts
    Local Time:
    2:59 AM
    I have a 71 duster drag car and when it rolls backwards it turns slightly to the left, steering wheel turns clockwise.
    What’s adjusted wrong?
    I don’t have any adjustment numbers, front end was set up many years ago and is somewhat worn out.
    Thanks
  2. Biff
    Biff Cheep not easy
    5,338
    9179
    Jan 30, 2017
    Middle of the ocean somewhere in Canada
    Local Time:
    12:59 AM
    It seems an alignment is in order , turning to the most caster , I think :steering:
  3. AJ/FormS
    AJ/FormS 68 B'cuda fb, Form S clone ... 367/A833/3.55s
    18,894
    6901
    Jan 19, 2014
    South-Central Manitoba,Canada, 900ftelevation
    Local Time:
    2:59 AM
    Dragging brake?
  4. gm1236
    136
    52
    Aug 3, 2013
    Massachusetts
    Local Time:
    2:59 AM
    I know it’s not the brakes, they are Strang and have very little drag. I’m going with the caster, more on one side than the other maybe?
    • Agree Agree x 2
    • Demonracer
      Demonracer 71 Demon 00 Ram 16 Chrysler 300S 05 Caravan FABO Gold Member
      3,794
      1729
      Jan 31, 2010
      Cleveland, Texas
      Local Time:
      2:59 AM
      Drag racing alignment specs; Camber 0* Caster + 1.5-2.0 Toe in 0-1/16".
    • AJ/FormS
      18,894
      6901
      Jan 19, 2014
      Local Time:
      2:59 AM
      Scrub radius? ie non matching backspace wheels.
    • RustyRatRod
      RustyRatRod Bla de blizhibliz de blatde blizi bla bla FABO Gold Member
      63,408
      36086
      Jun 7, 2010
      Georgia
      Local Time:
      3:59 AM
      Simple. Don't roll it backwards.
    • gm1236
      136
      52
      Aug 3, 2013
      Massachusetts
      Local Time:
      2:59 AM
      Goes nice and straight going forward, that’s all that maters!
    • toolmanmike
      toolmanmike FABO MODERATOR Staff Member FABO Gold Member
      51,865
      37142
      Jan 18, 2006
      Iowa
      Local Time:
      2:59 AM
      I had to correct your title. lol
    • gm1236
      136
      52
      Aug 3, 2013
      Massachusetts
      Local Time:
      2:59 AM
      Thank you!
      How do you do that?
    • toolmanmike
      51,865
      37142
      Jan 18, 2006
      Iowa
      Local Time:
      2:59 AM
      Under thread tools below the title to the right. I think you can see that as a member.
    • gm1236
      136
      52
      Aug 3, 2013
      Massachusetts
      Local Time:
      2:59 AM
      I did try to fix it, couldn’t figure it out. Now I’ll know what to do next time.
      Thanks again toolmanmike.
