flyinbysocal
Member
Hi all. My 1964 Dart GT always gets up to the low end of the operating range on the engine temperature gauge. Well yesterday, after driving for 10 minutes it, the temperature needle was moving toward the upper end of the operating range, where I've never seen it go. So I went home and parked it. I also noticed some clear-ish fluid draining from the drain tube under the very front of the car, which I have not noticed before. The engine block read 195 degrees using my hand-held temperature gun (not sure if this is an expected temp or not). I came out 10 minutes later to pull it into the garage, and the car wouldn't start. After multiple attempts, the battery sounded drained. 2 hours later, I jumped the car and it started right up. I pulled it into the garage, where it sits now. I initially figured it wouldn't start because it's time to replace my old battery. But then I thought, maybe the battery draining is related to the rise in temperature on the engine temperature gauge. I am by no means an auto mechanic, but I do minor jobs myself. Any thoughts on what the issue could be? Thanks in advance!
