Carb and throttle cable help
Mopar General Discussions
  1. Jeremiah David
    Jeremiah David Active Member
    30
    13
    May 17, 2017
    Colorado
    Local Time:
    2:54 PM
    I'm having trouble getting the throttle cable hooked up to my new carb. Problem is throttle cable is to long. When the cable should be going back, as of you let off the gas, the cable bends up and doesn't go all the way back in.
    My question is should I cut the cable and use a new clamp to hold the cable, or do I buy a new shorter one?
    Specs
    1973 Plymouth Duster
    72 360 out of a cuda
    Edlebrock 1406 carb
    IMG_20190531_160327.jpg IMG_20190531_160359.jpg IMG_20190531_160351.jpg IMG_20190531_160339.jpg
  2. hoosierdaddy
    hoosierdaddy FABO Gold Member FABO Gold Member
    438
    195
    Nov 13, 2008
    Central Indiana
    Local Time:
    4:54 PM
    I don't see the clamp for your throttle cable , without it your cable housing will move and not allow the throttle to work .
  3. Jeremiah David
    30
    13
    May 17, 2017
    Colorado
    Local Time:
    2:54 PM
    I disconnected it for now, but I have the clips and all that were used on the old carb. I have it laying there to show how much further the cable goes past the linkage.
  4. hoosierdaddy
    438
    195
    Nov 13, 2008
    Central Indiana
    Local Time:
    4:54 PM
    Just curious what the cable is suppose to fit ? You can modify what you have , I believe all you would is an adjustable fitting at the carburetor end or just buy a Lokar style throttle cable .
  5. Jeremiah David
    30
    13
    May 17, 2017
    Colorado
    Local Time:
    2:54 PM
    I am pretty sure it's the stock cable. It was hooked up to my old carb, but they had the excess cable by the firewall. When I try to do what was done before it keeps bending the cable.
    I have a connection to run the cable through if I cut it, but just not sure I want to do that.
  6. Murray
    Murray FABO Gold Member FABO Gold Member
    1,120
    646
    Apr 19, 2010
    San Jose, California
    Local Time:
    1:54 PM
    Remember this is an adjustment at the cable clamp. Pull the cable back towards the firewall to remove any freeplay and then tighten the clamp. This "sets" the length of the cable between the clamp and the carb. You may also need an adapter for Mopar linkage.
  7. Jeremiah David
    30
    13
    May 17, 2017
    Colorado
    Local Time:
    2:54 PM
    I had put it in the clamp and pulled slack, but it was still giving me issues. I'll look into the linkage though.
  8. tonysrt
    tonysrt FABO Gold Member FABO Gold Member
    524
    201
    Dec 25, 2016
    Northport, NY
    Local Time:
    4:54 PM
    Was that an original 318 engine car? I have a 74 original 318, put a 4bbl manifold on and throttle cable worked for me. I switched from 2bbl manifold to 4bbl.
  9. jaws
    jaws I put the fun in dysfunctional FABO Gold Member
    3,192
    1432
    Sep 11, 2006
    Strasburg Colorado
    Local Time:
    3:54 PM
    Looks like a slant cable. Dos you have the bracket that bolts to the intake?
    • Agree Agree x 1
    • Mike69cuda
      Mike69cuda 64 is the new 17 FABO Gold Member
      778
      517
      Jan 2, 2018
      Overland Park Kansas
      Local Time:
      3:54 PM
      There are a lot of threads on here about this issue. They were very helpful when I did mine.
      The cable looks too long. Maybe a /6 as mentioned earlier. If it has been kinking it is time to throw it away. Very dangerous to use a damaged throttle cable.
      I don’t see a kick down rod so I assume it is a stick. That makes life easier. Mancini racing sells a 4 barrel bracket that can replace the one on your engine if yours was originally a 2 barrel. Guys on here probably have them too. This maybe needed if you run a stock cable.
      There is a mopar specific u shaped throttle bracket for a Holley, don’t know if would fit yours. Probably not needed if you have a stick as I think it is designed mostly for the kick down linkage on an auto. I have one I didn’t use I will give you if you want it, but I don’t think it will help.
      Looks like the easiest way may be to get a Lokar cable as suggested above. I looked at them but didn’t buy as they are very pricey.
    • RPMagoo
      RPMagoo Just An Old Motorhead
      2,802
      1273
      Nov 4, 2015
      N.E. Pa.
      Local Time:
      3:54 PM
      I have 3. All different lengths. -- The middle one is different, on the firewall end. --- Throttle Cable - 2.JPG
      • Agree Agree x 1
      • H22A4
        H22A4 Well-Known Member
        1,611
        483
        Aug 4, 2006
        YVR
        Local Time:
        1:54 PM
        Once you have your throttle cable issue figured out be sure to ditch that rubber fuel line to your carb. That’s a disater waiting to happen.... fuel, hot engine and that rubber hose is going to melt/spring a leak which will mess up that nicely painted engine!
      • JoeSBP
        JoeSBP RLTW!
        1,208
        645
        Jun 16, 2015
        NC
        Local Time:
        4:54 PM
      • Jeremiah David
        30
        13
        May 17, 2017
        Colorado
        Local Time:
        2:54 PM
        It's only there until I can get a fuel rail.
      • tonysrt
        524
        201
        Dec 25, 2016
        Northport, NY
        Local Time:
        4:54 PM
        He never responded to what engine was in the car previously.
      • Jeremiah David
        30
        13
        May 17, 2017
        Colorado
        Local Time:
        2:54 PM
        Sorry I work nights and got off at 6 am this morning. Yes the original was the 318 in the car.
      • AJ/FormS
        AJ/FormS 68 B'cuda fb, Form S clone ... 367/A833/3.55s FABO Gold Member
        16,302
        5068
        Jan 19, 2014
        South-Central Manitoba,Canada, 900ftelevation
        Local Time:
        3:54 PM
        That carb linkage ain't Mopar either, and the front spring-anchor is way too low and the rear bracket looks like a 2bbl to me, and is also too low. You'll be wearing out your carb's baseplate in no time.I don't see the Vcan hooked up either. and I never saw a PCV hose that looked like a fuel line, engine vacuum and head will conspire to suck fuel-line flat.
      • Jeremiah David
        30
        13
        May 17, 2017
        Colorado
        Local Time:
        2:54 PM
        So I have a lot to learn still. I was matching up how the guy I got it from had the Holley hooked up. What am I doing wrong and what do I need to fix? Sorry if it's to many questions, but I want to make sure I do it right. This is the first time I've swapped a carb.
      • Jeremiah David
        30
        13
        May 17, 2017
        Colorado
        Local Time:
        2:54 PM
        The carb I pulled off was a Holley 750cfm 4 barrel. I wanted something smaller that would work with engine better. I'm looking at ordering a new throttle cable somebody posted up in here as well.
      • AJ/FormS
        16,302
        5068
        Jan 19, 2014
        Local Time:
        3:54 PM
        • Agree Agree x 1
        • Jeremiah David
          30
          13
          May 17, 2017
          Colorado
          Local Time:
          2:54 PM
        • Mattax
          Mattax Just the facts, ma'am FABO Gold Member
          7,000
          3966
          Feb 7, 2013
          Phila. Pa
          Local Time:
          4:54 PM
          Those parts should be on the holley you removed.
          You can transfer them.
          I don't know if the will transfer to the new Eddy thats on your engine.
          The stud probably yes. The extension might need to be an Edlebrock version.
        • Jeremiah David
          30
          13
          May 17, 2017
          Colorado
          Local Time:
          2:54 PM
          I'll post pictures of the Holley when I get up. I work nights and just got home from work.
        • Johnny Dart
          Johnny Dart Well-Known Member
          7,407
          1572
          Nov 30, 2006
          So Cal
          Local Time:
          1:54 PM
          Onm.
          • Like Like x 1
          • Mattax
            7,000
            3966
            Feb 7, 2013
            Phila. Pa
            Local Time:
            4:54 PM
            There's also later style throttle linkage brackets from whenever Dodge/Plymouth stopped using the three piece automatic transmission throttle linkage.
